Results 1 to 17 of 17
Thread: camber correcting
    87 honda accord dx
    cave creek
    camber correcting
    ok, i need to fix my camber. so i need to know if its possible to make my own camber kit, and how. or if i should just get the 2nd gen lude arms. i want to know how much they are and what exactly i have to do to get them to work. oh, by the way, its only in the front. thanks.
    no
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    The 2nd gen lude arms would be your cheapest option. They will run you probably $30-40 at the yard and new ball joints ($~30 a side) is recommended. Eric (POSCarb) has a how-to on it here
    http://quadmobile.virtualave.net/LudeArms.htm
    Oct 2001
    87 Accord EX , 5spd , Manual
    i 'll add this to the how to's if it's not there !
    MIKE
    87 honda accord dx
    cave creek
    i dont see it on there. so if you could add a how-to, it would be perfect.
    no
    Oct 2001
    it's there now !
    MIKE
    SEi User
    burgundy 86 honda accord/ brown 89 chevy caprice wagon
    one of the other things ive noticed over time is that the increased length of the prelude arms makes the car handle better. when turning and diving into a corner you dont get such a positive rool in the camber and caster curves. makes the car much more stable in a high speed corner.
    good stuff.
    Want your A series to kick a B series engines ass?email me for detials or check out our site
    WWW.ACCORDCENTRAL.COM
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    AIM Industries has a set of adj. upper arms that are good for 4 degrees!
    139.99
    www.truckn-store.com
    Travis
    87 honda accord dx
    cave creek
    ok, i just got the upper arms from the junk yard, cost me $67. anyway, iam going to put them on tomarrow probably. thanks for that how to, its gunna help alot.
    no
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Changing the length of the upper arm (what you are doing) will affect not only your camber, but will also change your toe settings. Plan to get an alignment as soon as you're done. For $67 I'd hope that the ball joints and seals were in good condition. My arms without joints were $30.
    Mike
    87 honda accord dx
    cave creek
    yeah i know that i gotta to that, do you know about how much its gunna cost me to get that done? the joints are definitly in good shape, so i got lucky there.
    no
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    When I called around Tucson for a 4-wheel alignment, the best deal was $50 at a Honda dealer. If you're confident about your rear wheels you could just get a front-end alignment for $10-20 less. Plan to pay $35-60 depending on what you choose to do and whether on not you find any good deals.
    Mike
    87 honda accord dx
    cave creek
    wow, thats fairly cheap. i dont know about my rear wheels, i might just do a front end because theres really nothing to do about the rear. well, if i finish putting the arms on today, ill go get one. thanks mike.
    no
    87 honda accord dx
    cave creek
    is there anyplace that would have the new upper ball joints in stock so that i can get them by tomarrow?
    no
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I thought that you said that yours were in good shape. I got mine at an Autozone for $35 each. I called around and found that one of the 24 hour locations had some in stock.
    Mike
    87 honda accord dx
    cave creek
    yeah, my dad decided that he wanted some new ones too. so i am going to find them for him, and then hes gunna pay for mine
    no
    Jul 2002
    89 accord dx/efi conversion
    Dayton, Oregon
    how much longer are the arms? if you were to guess up to how many degrees would it fix? I have a camber kit and it is as far out as it will go and my camber is still off around 2.0 degrees. My car is lowered about 2 3/4". Would i be able to fix my camber with those arms.
    shaved doors, trunk, squirters, antenna/ molded 90 accord tails, 90 accord rear bumper/ custom tan and cardinal tweed interior(everything)custom speaker pods/ 16"chrome rims/ lowered 3"/ custom exhaust/efi conversion
    87 honda accord dx
    cave creek
    yeah probably. i think that thats pretty much your only other option. actually i konw you would be able to because you can modify them even more for more adjust ability by making the slots longer. so i would go get some.
    no
  1. Camber```
    By -$MOKIN- in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-03-2009, 09:09 AM
  2. *FS - New Camber Kit!*
    By accorddude in forum Trading Post
    Last Post: 10-29-2003, 02:19 PM
  3. Camber
    By wallacefan in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-28-2003, 09:53 AM
  4. camber
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-13-2003, 10:36 PM
  5. Camber adj.
    By Metro in forum 3geez Accords
    Last Post: 01-04-2003, 07:17 AM
