Results 1 to 4 of 4
Thread: brake problem when holding the brake
    Feb 2016
    1989 honda accord lxi
    hickory nc
    ok guys could use some help. on my 89 accord lxi when im say in a parking spot holding the brakes, the pedal just kinda slowly goes to the floor and once its there if i let off even a centimeter the car starts rolling but once i start driving it's fine. even pumping the brakes does nothing. but its only holding them for a long period of time that it does that. and the reservoir is full.
    conozo's Avatar
    Fort Wayne, Indiana
    Re: brake problem when holding the brake
    Hi, We just had someone else with a brake booster problem in another thread scratching-my-head-brake-booster-troubleshooting
    I think you have a failing brake booster. To test you need to get a vacuum pump and see if the booster holds a vacuum. Also in the shop manual which is available here on this site by search, will give you diagnostic tests to preform.
    1988 Honda Accord LSDX-I
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    as Conzo mentioned i would get a vac gauge to confirm that the booster is holding. it is also a possibility that there is air or a leak in your system.
    3Geez resident body man
    Owner of Wreck-less auto body
    This is classic master cylinder failure.
  1. Brake Problem
    By partyharty in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-05-2008, 09:15 AM
  2. brake problem
    By Kemikals in forum EFI Tech
    Last Post: 09-03-2007, 07:05 AM
  3. Replies: 21
    Last Post: 04-17-2006, 07:02 PM
  4. 89 Accord LX - Brake/Horn Fuse Blowing When Brake Pressed.
    By Glowin Smurff in forum 3geez Accords
    Last Post: 02-25-2004, 08:34 AM
  5. brake problem please help
    By inflikti0n in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-15-2003, 02:26 PM
