Page 12 of 25 FirstFirst ... 2891011121314151622 ... LastLast
Results 276 to 300 of 617
  1. #276
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    I may have a cluster. Ill check in the am
    Sent from my SM-N920P using Tapatalk
    Cool . I need to ask you about the intake manifold since I'm running a stock intake manifold are there any OBD1 sensors on the B16 manifold I would need for 0bd1
  2. #277
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    OBD1 map sensors are on the the tb and obd0 is in the black box so you'll have to extend the wires to reach but that's about it
  3. #278
    Feb 2016
    Florida
    Cool thanks
  4. #279
    Feb 2016
    Florida
    Leaky rear brake cylinders replaced. And stainless brake lines installed. Glad that's done
ID:	8298   Click image for larger version.
ID:	8299   Click image for larger version.
ID:	8300   Click image for larger version.
ID:	8301   Click image for larger version.
  5. #280
    Feb 2016
    Florida
    Seems like everytime I turn around I got some kind of leak.power steering pump seal hell of a mess got a rebuild kit
ID:	8315   Click image for larger version.
ID:	8316   Click image for larger version.
  6. #281
    Keep going. You'll get there.
  7. #282
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    +30 year old car, you expect things like seals to last forever?
    3Geez resident body man
    Owner of Wreck-less auto body
  8. #283
    Feb 2016
    Florida
    no it seems like when these cars break down multiple things happen in a row. Fix one problem to find another
  9. #284
    its worth it once everything is done.
    Feb 2016
    Florida
    I know I think I'm getting pretty close
  11. #286
    Feb 2016
    Florida
    Swap to the 89 cluster today and I can say I now have a VSS signal it is pretty accurate. It even shows what gear I'm in based on RPMs and speed .And I'm seeing my old cluster and that I never seen the check engine light on because someone remove the bulb
ID:	8384   Click image for larger version.
ID:	8385   Click image for larger version.
ID:	8386   Click image for larger version.
  12. #287
    Feb 2016
    Florida
    To get a vss signal to your 86 cluster you only need to swap the plastic white box from a 89 cluster I give Rendon LXI the credit thanks bro
ID:	8388   Click image for larger version.
ID:	8389   Click image for larger version.
  13. #288
    Great tip.
    Get that afr down!
  14. #289
    Feb 2016
    Florida
    Great tip.
    Get that afr down!
    Thanks. I know been having problems with the sensor/ signal.i switched from pin D14 to pin B6 for a more Clear signal seems to be working great now
  15. #290
    Feb 2016
    Florida
    Well the water pumps leaking I don't know how I forgot to replace that and the timing belt when I had it all apart. One step forward two steps back as soon as I can get all the leaks and bugs fixed I might be able to put a turbo on it one day
ID:	8409   Click image for larger version.
  16. #291
    Feb 2016
    Florida
    You really can't tell much of a difference but I did a wire tuck on one side without cutting or extending any wires. Still got a lot of work to do
ID:	8421   Click image for larger version.
ID:	8422   Click image for larger version.
ID:	8423   Click image for larger version.
ID:	8424   Click image for larger version.
ID:	8426   Click image for larger version.
ID:	8428   Click image for larger version.
  17. #292
    Feb 2016
    Florida
    Tucking wires little by little
ID:	8451   Click image for larger version.
ID:	8433   Click image for larger version.
ID:	8434   Click image for larger version.
ID:	8442   Click image for larger version.
ID:	8444   Click image for larger version.
ID:	8445   Click image for larger version.
  18. #293
    Feb 2016
    Florida
    I'm trying to wire in a OBD1 throttle body map sensor .I know the pin out on the OBD1 clip. But I need to know the signal ground and Power on the OBD0 stock harness side. I've been testing with a stock OBD1 sensor tried different wiring combinations and having no luck possibly a bad sensor. Found wire diagram just waiting on sensor
ID:	8452   Click image for larger version.
ID:	8453   Click image for larger version.
ID:	8454   Click image for larger version.
  19. #294
    Feb 2016
    Florida
    From the testing I'm done I say that you can not use a obd1 throttle body map sensor as a firewall map sensor. it didn't work for me.
ID:	8464   Click image for larger version.
  20. #295
    when you say map sensor are you meaning the Throttle position sensor. Or you mean a Manifold pressure sensor?
  21. #296
    Feb 2016
    Florida
    Map manifold pressure sensor. Obd1 throttle body map sensor + Mount to firewall= no go
  22. #297
    Feb 2016
    Florida
    Fuse box relocated. I hate wires it's too hot in Florida
ID:	8485   Click image for larger version.
ID:	8486   Click image for larger version.
ID:	8487   Click image for larger version.
  23. #298
    LX User rushell's Avatar
    Oct 2012
    looks like fun
  24. #299
    Feb 2016
    Florida
    Quote Originally Posted by rushell View Post
    looks like fun
    yes sir it has been a real chore. I think I did it ass backwards I relocated the fusebox before I relocated the battery to the trunk/hatchback. I just need a good sealed battery box before I move it
ID:	8505   Click image for larger version.
ID:	8506   Click image for larger version.
  25. #300
    Feb 2016
    Florida
    Wires cleaned up and fuse box mounted
ID:	8511   Click image for larger version.
ID:	8512   Click image for larger version.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
