Page 13 of 25 FirstFirst ... 39101112131415161723 ... LastLast
Results 301 to 325 of 617
  1. #301
    Anything you can get moved away from the heat of a turbo is a good thing.
  2. #302
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Yes sir and it also makes the engine bay look a lot cleaner
  3. #303
    Feb 2016
    Florida
    2step on/off switch
  4. #304
    Feb 2016
    Florida
    video before obd1
  5. #305
    Feb 2016
    Florida
    I just learned how to post videos so here's a walkthrough current progress
  6. #306
    Feb 2016
    Florida
    The Accord is down for a minute. I like to thank Seth witte AKA blocks for getting me the correct cam Tower. Got the cam Tower swapped out but in the 1500 mile run it damage my distributor key. So I decided to make my own distributor plate until I can get another key. I went and got my timing belt and water pump swapped out along with the new can Tower.
ID:	8547   Click image for larger version.
ID:	8548   Click image for larger version.
ID:	8549   Click image for larger version.
ID:	8550   Click image for larger version.
ID:	8552   Click image for larger version.
ID:	8553   Click image for larger version.
  7. #307
    LX User AWH's Avatar
    Feb 2017
    Honda Prelude BA2 1987 2.0i-16V. B20A1
    the Netherlands
    Bad luck man,but you'll get it fixed. What happened to the camtower ? Camshaft still ok ? So you're running another type of distributor right now ? The one you had before obd swap ? New timing and waterpump is a pro though
    You still manage to find parts,a job on it's one.
    Auke.
  8. #308
    Feb 2016
    Florida
    Quote Originally Posted by AWH View Post
    Auke.
    The cam Tower I had on there was from a carbureted Accord and it didn't hold the distributor plate flush or level and that damage my custom distributor key . Camshaft fine. I'm making a plate and modifying a OBD1 distributor to run until I can get another key. if you search hard enough you can find good parts for cheap. I got the OEM timing belt for $17 on eBay it's a 1985 Honda Accord OEM timing belt. And the OEM water pump was $22
ID:	8555   Click image for larger version.
  9. #309
    Feb 2017
    the Netherlands
    I agree, fairly common parts are all over the place. My problem with E-bay is that most of the time the shipping -costs equal or even double the cost of the part,living in Holland. But more specific engineparts are getting harder and harder to get,especially if there is no junkyard around with your type Honda. Right now i cannot find an oem 2 gen. dual-tip muffler (or anything close) in the world. Ordered a 3gen.muffler and hope to make it fit when and if it arrives..
    Can't you weld a drop onto the camkey and reshape it ?
    Auke.
  10. #310
    Feb 2016
    Florida
    Auke.
    I forgot you were overseas but I can imagine it's a pain in the ass to get parts. I thought about welding it but the way the material just chipped away I don't think that's something I could trust going under boost
  11. #311
    Feb 2017
    the Netherlands
    Bummer. You might be right,better do it the right way and feel safe about it.
    Auke.
  12. #312
    Feb 2016
    Florida
    I decided to go ahead and remove the power steering pump and lines and loop the rack to a reservoir on the firewall. I know that's not the correct way to do it.other options would be to try to find one overseas manual rack with the subframe or try to modify one from a second generation Honda Accord. But that could be pricey so fuck it. Y.o.l.o.
ID:	8567   Click image for larger version.
ID:	8568   Click image for larger version.
ID:	8569   Click image for larger version.
  13. #313
    Feb 2017
    the Netherlands
    Why remove it ? Are you going without powersteering ? Do you need the space or did something break ? Or was it that your rack and pinion went down a while ago and you can't fix it for now ? Bad experience with remanufactured ones it was ?
    Auke.
  14. #314
    Feb 2016
    Florida
    Auke.
    Yeah I've been having problems with the rack leaking and the belts been off it for a while now. It's an oem rack from a 89. Tired of dealing with the headaches of power steering leaks and it did clean up the engine bay a lot and a lot more room. It's going to be a turbo car soon so I'm really not too worried about it. But I'm in the process of finding another OEM rack
  15. #315
    Feb 2017
    the Netherlands
    Btw,is it possible to install a new waterpump without having to open up and disassemble the distributiontimingbelt/parts ? So is just taking the old waterpump out and replacing it easily done ?
    Auke.
  16. #316
    Feb 2016
    Florida
    Auke.
    The first time I ever had to change my water pump I was a kid and I was able to take a pair of tin Snips and just cut part of the plastic away but many years later and many miles it warped the cover and end up getting tore up and eat out by the pulley. I end up getting the new cover . So yes if you want to keep the cover it hides like two bolts of the water pump other than that it's taking the pulley and belt off
  17. #317
    Feb 2017
    the Netherlands
    Sure i want to keep the cover..it's there for a reason. Just did the timingbelt last year (sigh) with a mate who has a lift,i know we had to lift the engine then,not sure if that was for just taking off the cover. Believe it was to reach the crankshaftpulleybolt. Well,i guess i just go and see what it takes. Believe my waterpump it starting to fail,or it is the dynamo next to it,starting to hear a very soft squeeling sound,like a bearing going bad or something but i cant make out which one it is. Maybe a bit further down the road it will be more obvious.
    Auke.
  18. #318
    Feb 2016
    Florida
    Auke.
    I don't know about the preludes but I just turned the wheel all the way to the left plenty of room to get to the lower crankshaft bolt. No lift required
  19. #319
    Feb 2017
    the Netherlands
    Well,at the Prelude you have to take the wheel off,then there is a hole in the chassis,and you have to lift the engine a few centimeters to align the crankshaftpulleybolt to the hole so you can get to it. A bit of work,but there is no other way.I guess they learned by the time your Accord was made
    Auke.
  20. #320
    Feb 2016
    Florida
    Auke.
    Damn sounds like a pain in the ass.maybe you can put a jack under the oil pan and jack it up a little that has to be done to remove the side mount and take the belt out
  21. #321
    Feb 2017
    the Netherlands
    I guess that would work with a piece of wood between jack and oilpan for even distribution of force.
    Auke.
  22. #322
    Feb 2016
    Florida
    A work in progress
ID:	8577   Click image for larger version.
ID:	8578   Click image for larger version.
ID:	8579   Click image for larger version.
  23. #323
    Hey that looks familiar!
    Feb 2016
    Florida
    yes sir I took you and Messy Honda's design. I got it on the car how's that look
ID:	8581   Click image for larger version.
ID:	8582   Click image for larger version.
ID:	8583   Click image for larger version.
  25. #325
    Feb 2016
    Florida
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
