Page 4 of 25 FirstFirst 1234567814 ... LastLast
Results 76 to 100 of 617
  1. #76
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Yes sir. this is just a rough estimate Outlook of it .I still got a lot of cleaning up and detailing .grinding / cutting to do to it thanks
  2. #77
    Feb 2016
    Florida
    Bisimoto heat shield intake manifold gasket came in today. Prepping front bumper for paint
ID:	7633   Click image for larger version.
  3. #78
    Feb 2016
    Florida
    Front bumper painted. Intercooler and accessories painted to blend in with the front bumper. Radiator fan installed wired up
ID:	7635   Click image for larger version.
ID:	7636   Click image for larger version.
ID:	7637   Click image for larger version.
  4. #79
    Feb 2016
    Florida
    New carpet came in today
  5. #80
    awsome! progress is dope!
  6. #81
    Feb 2016
    Florida
    Thanks dude. More parts ARP Rod studs part #208-6001
  7. #82
    hell yea.
  8. #83
    Feb 2016
    Florida
    Radiator plate cleaned up and painted to match the rest of the car. Preparing to disassemble motor. Time to get out the pressure washer and tools
ID:	7644   Click image for larger version.
  9. #84
    awww snap!
  10. #85
    Feb 2016
    Florida
    Cylinder head removed. Two broken studs. And aluminum piece that holds distributor fell apart. Trial and error !! WTB Aluminum distributor rocker arm piece and lower timing belt cover
ID:	7651   Click image for larger version.
ID:	7652   Click image for larger version.
ID:	7653   Click image for larger version.
  11. #86
    Pm me. I got one in a spare head in ga. Can ship next weekend
  12. #87
    Feb 2016
    Florida
    Thermal throttle body gasket receive today
  13. #88
    noice. going b series intake correct?
  14. #89
    Feb 2016
    Florida
    In the future this is for the stock manifold Part from p2r Power rev racing for 88-91 crx-si
  15. #90
    got ya.
  16. #91
    Feb 2016
    Florida
    Oil pan and pistons removed
ID:	7665   Click image for larger version.
ID:	7666   Click image for larger version.
  17. #92
    Feb 2016
    Florida
    Pistons cleaned up and ARP Rod studs installed. ARP Rod studs are a hair shorter than stock. A tip for anyone installing these take your time when you install the new studs. It's best to tap and tighten tap and tighten. So that heads just twist on you.
ID:	7668   Click image for larger version.
ID:	7669   Click image for larger version.
  18. #93
    Feb 2016
    Florida
    Turbo return line oil pan fitting installed
  19. #94
    Feb 2016
    Florida
    Valve cover painted. That is all for this weekend
ID:	7675   Click image for larger version.
  20. #95
    I like ur style
  21. #96
    Feb 2016
    Florida
    Do I need these parts ?
ID:	7682   Click image for larger version.
  22. #97
    DX User Samwise's Avatar
    Aug 2011
    '89 DX Sedan (RIP), Very Special '87 LX-i Hatch
    Those are your idle solenoid and AC idle-up. It looks like you're going OBD1, so they'll be useless.
    Proud new owner of Catalyst's hatchback
  23. #98
    Feb 2016
    Florida
    Cool thanks. I want to remove everything I'm not going to need
  24. #99
    Feb 2016
    Florida
    "Update" Pistons back in oil pan back on transmission removed. More Parts fuel pump relay kit from xenocron and 0bd1 distributor
ID:	7687   Click image for larger version.
ID:	7688   Click image for larger version.
ID:	7689   Click image for larger version.
ID:	7690   Click image for larger version.
  25. #100
    Unbolt that battery tray lol
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
