Page 5 of 25 FirstFirst 12345678915 ... LastLast
Results 101 to 125 of 617
  1. #101
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    You don't like my tray yeah I was thinking about doing something with that .like relocate the battery and I was thinking about maybe dropping the battery down some inn its existing spot
  2. #102
    DX User Samwise's Avatar
    Aug 2011
    '89 DX Sedan (RIP), Very Special '87 LX-i Hatch
    I'd relocate it to the trunk.
  3. #103
    Trunk is best bet imo. Do that & a fuse box relocation under the glove box(ull have to do something custom for blower hose) & ill have all the extra space ull need
  4. #104
    Feb 2016
    Florida
    Can I remove this little harness I believe it was all the connectors for the Ac components driver side in front
  5. #105
    Feb 2016
    Florida
    Arp flywheel and pressure plate bolts. Flywheel bolts may be a little long
ID:	7693   Click image for larger version.
ID:	7694   Click image for larger version.
  6. #106
    Feb 2016
    Florida
    Rhino Puck brand flywheel came inn today finally i can put it back together
ID:	7725   Click image for larger version.
ID:	7726   Click image for larger version.
ID:	7727   Click image for larger version.
ID:	7728   Click image for larger version.
  7. #107
    Feb 2016
    Florida
    And other parts transmission axle seals spark plug ball joints oil pump gaskets all the little accessories you need
  8. #108
    What clutch did you get? The stage 2 I had wasn't able to Handel 220whp
    Edit: I see its a 2+. You may be cutting it close with that one. 203tq rated. If you get a good time & everything right that may be your weak point
  9. #109
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Id like to know as well spec d was the only place I contacted last year that had something that would hold over 300 horsepower
    Sent from my SM-N920P using Tapatalk
  10. #110
    Id tell ya to do what I did for my clutch, hit up a local shop that has been building clutches for diesel trucks. My local place made mine for like 220ish and had a 3day turn around cuz they had to wait on a material order. Dude said its good up to 400 sooooo....
  11. #111
    Feb 2012
    89/accord/lxi
    That's true but I was more interested in a more heavy duty pressure plate and that seems to be a little bit hard to find
  12. #112
    Feb 2016
    Florida
    Yes sir its level 2 + I was originally going to go with a clutch master one but it was out of my price range at the time. It seems like it's hard to get past that 220 whp mark. I'm not trying to break any world records right now. Thanks for all the info guys we will see how it goes
ID:	7730   Click image for larger version.
  13. #113
    Feb 2012
    89/accord/lxi
    I have been thinking about this because price point isn't to bad
    SPEC Clutch Stage 4 - Honda Accord 1986-1989 2.0L SPEC Clutch SH084
  14. #114
    Feb 2016
    Florida
    Yeah man that's actually cheaper than what mine cost. I purchased the level 2 plus because I live in like a tourist town a lot of stop-and-go traffic and I wanted to still be able to handle it in the streets. Let me know how it goes. My plans are to put it all back together do a good 500 mile break in on it convert to OBD1. Then turbo it
  15. #115
    500mile break in is false. You just need to heat cycle the clutch a few good times. Guy from competition clutch told me this. Saying 500 miles is just the safest way to cover heat cycles
  16. #116
    Feb 2012
    89/accord/lxi
  17. #117
    Feb 2016
    Florida
    Thank you for all the info I did not know that. haven't had time to work on it much with work and the weather. I will keep this in mind thanks
  18. #118
    why you not turn up the boast?!
    this build is looking cool. Cant wait to see this project in the future.
    Feb 2016
    Florida
    Quote Originally Posted by messyhonda View Post
    x2
  21. #121
    Feb 2016
    Florida
    Thanks you Messy for your support. It gives me motivation I appreciate it. Little update the Honda has been my daily driver for 13 years. I purchased another vehicle so now the Honda is my project vehicle. Money's been a little tight. And work has been very busy. I'm getting ready to work on it right now should have some good updates within the next couple days
  22. #122
    Feb 2016
    Florida
    Rack and pinion replaced, transmission shaft seals replaced, flywheel replace pressure plate and clutch disc installed.
ID:	7746   Click image for larger version.
ID:	7747   Click image for larger version.
ID:	7748   Click image for larger version.
ID:	7749   Click image for larger version.
  23. #123
    Hell yea! Keep it up man! Your getting closer every week!
  24. #124
    Feb 2016
    Florida
    Thanks boss man. should have some more good updates after this weekend
  25. #125
    we share a similar story. My mom bought one new back in 1988. it was my first car but she had an automatic carb. I bought mine right out of high school 10 years ago and now im proud to say its one of the fastest accords on the site. glad to see other people working on our cars. like i say old accords just get faster.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
