Page 7 of 25 FirstFirst ... 3456789101117 ... LastLast
Results 151 to 175 of 616
  1. #151
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    90-93 Honda Accord MSD external coil cap set up
  2. #152
    staying external coil? I went internal just for less wires
  3. #153
    Feb 2016
    Florida
    Yes sir keeping it old-school
  4. #154
    Feb 2016
    Florida
    Lost my job today so it looks like the head go's back together with the Single Springs on the intake side
  5. #155
    Feb 2016
    Florida
    I can verify that the bisimoto double valve spring fit stock intake retainers no problem perfect fit
ID:	7795   Click image for larger version.
ID:	7796   Click image for larger version.
ID:	7797   Click image for larger version.
  6. #156
    Feb 2016
    Florida
    Cylinder head installed and torque to specs. Should have it running tomorrow
  7. #157
    Feb 2016
    Florida
    Latest progress .engine oil cooler plate and lines installed intake installed. rocker arms camshaft timing lined up. Sizeing up manifold for downpipe. And for anyone that's going to try to run the mosselman turbo header you're going to need A 1 inch turbo spacer in between the turbo and manifold this will push the turbo far enough past the front motor mount you still got it cut a little bit of the bracket but not as much. And you're going to need the front motor mount adapter plates with the energy suspension GM motor mounts. That gives you room for oil return line fitting
ID:	7801   Click image for larger version.
ID:	7802   Click image for larger version.
ID:	7803   Click image for larger version.
ID:	7804   Click image for larger version.
ID:	7806   Click image for larger version.
ID:	7807   Click image for larger version.
  8. #158
    Looking good! Sorry to hear about the job.
  9. #159
    sucks you lost your job man, i know thats rough. but progress looks nice! where are you mounting your oil cooler? I'm trying to plan out mine so I can add it in the winter. also any way to rotate your pics the correct way lol
  10. #160
    Feb 2016
    Florida
    It's all good it was a bunch of bullshit they actually called me back and said I could come back to work
  11. #161
    Feb 2016
    Florida
    The engine oil cooler radiator is going to go to the right of the half size Civic radiator I will have pictures of it installed tomorrow
  12. #162
    Feb 2016
    Florida
    And the internal wastegate actuator valve bracket has to be modified
ID:	7809   Click image for larger version.
ID:	7810   Click image for larger version.
ID:	7811   Click image for larger version.
  13. #163
    Feb 2016
    Florida
    Need one more elbow for the downpipe otherwise I would have to cut out a large chunk of the crossmember
ID:	7814   Click image for larger version.
ID:	7815   Click image for larger version.
  14. #164
    get a traction bar. or take a hammer to the downpipe. it dont matter lol
  15. #165
    Feb 2016
    Florida
    Lol I thought about it believe me
  16. #166
    Feb 2016
    Florida
    Valve Lash adjusted .valve cover back on distributor back on Old exhaust back on radiator back inn and here's where I'm going to mount my engine oil cooler radiator
ID:	7817   Click image for larger version.
ID:	7818   Click image for larger version.
  17. #167
    Feb 2016
    Florida
    Engine oil cooler radiator installed. Down to puting in the drive shafts , rotors and front Knuckles and fluids
ID:	7822   Click image for larger version.
  18. #168
    So how are you going to mount your intercooler?
  19. #169
    Feb 2016
    Florida
    my intercooler is mounted right under the metal bumper . Fully got it back together front bumper and everything it was too dark to take any pics will have some tomorrow
  20. #170
    Feb 2016
    Florida
    The oil cooler radiator sits where the old AC radiator set and the intercooler is mounted directly under the front bumper. Got it all oiled up and primed and we have a crank no start situation no power to the fuel pump or fuel pump is not working. So now I'm putting together my fuel pump relay kit going to try to get that out and go from there
ID:	7827   Click image for larger version.
ID:	7828   Click image for larger version.
  21. #171
    Feb 2016
    87 lx
    Austin texas
    What brand and size oil cooler are you running?
  22. #172
    Feb 2016
    Florida
    Quote Originally Posted by Ryon Toth View Post
    The brand is Bobo / eBay generic it came with my kit the size is 4 1/2 inches tall by 12 inches long 2 inches thick and the fittings are an 8
  23. #173
    Feb 2016
    Florida
    Fuel pump relay kit put together. And black box disassembled
ID:	7830   Click image for larger version.
ID:	7831   Click image for larger version.
  24. #174
    Feb 2016
    87 lx
    Austin texas
    Thanks bro! I need to get one
  25. #175
    Feb 2016
    Florida
    Oil catch can and lines installed and MSD Blaster coil mounted. Final elbow piece came in for my downpipe
ID:	7833   Click image for larger version.
ID:	7834   Click image for larger version.
ID:	7835   Click image for larger version.
ID:	7836   Click image for larger version.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
