Page 19 of 25 FirstFirst ... 9151617181920212223 ... LastLast
Results 451 to 475 of 617
  1. #451
    me too but we got Shane the main man on the case now so theres hope for us old guys.
    maybe he just got his spark plug wires wet and all is good in the A20 world again.
  2. #452
    I called the local Smog Referee about doing a RSX swap into the Accord. He's THE GUY who will be crawling all over the finished product, supposedly checking all the part numbers, deciding whether I get to keep it on the road when it's done.
    One, he didn't seem to know very much about cars, or engine swaps, or smog requirements. On that point alone it was a very disappointing call. But two, he actually tried to talk me out of doing a swap to OBD 2. He said that it would be too hard to get passed and a lot of people really struggle with it, so just stick with OBD 1. (Truth be known, HE'S probably the one who struggles with figuring it out).
    I was shocked. These CARB bureaucrats hold themselves out as being the people who are cleaning up our air, but here I am wanting to clean up the air, and they're talking me out of it!! They actually WANT me to drive around in an old worn-out car, dirtying the air. The smog regs are so onerous now that it's easier to drive around in a car leaking oil and coolant, with worn out smog controls, than to upgrade it and make it better. When I asked the referee if there was any realization among regulators that their overweening smog regs are actually counterproductive, the question went right over his head.
    What a joke.
  3. #453
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    I let it dry out and it's still knocking so we're proceeding to pull it all out
  4. #454
    That one bad ass A20 there.......
  5. #455
    Feb 2016
    Florida
    Thanks so far it's looking like one bent rod
  6. #456
    Feb 2016
    Florida
    We got it almost all tore all down and looking like three out of four are bent
  7. #457
    Looks like your rods were at the Funhouse Carnival Mirror Tent too long.
  8. #458
    Bent but not broken!
  9. #459
    LX User rushell's Avatar
    Oct 2012
    same thing happen to me two years ago broke the number 1 rod i put in another motor
  10. #460
    Eek! Good luck on the rebuild.
  11. #461
    Feb 2016
    Florida
    It's getting there hopefully we'll have it back together and running in tomorrow.
  12. #462
    Hit us with the details when your caught up. Those are some fresh looking cylinder bores.
  13. #463
    ohhh that hone does look fresh. am intrested
  14. #464
    Feb 2016
    Florida
    Replacement rods Pistons Rings fresh rebuild. back on the streets.
  15. #465
    Put some anti freeze in that baby dont let it freeze tonight! Or get up in the middle of the night and start it.
    Did you put in the new trans too?
  16. #466
    Feb 2016
    Florida
    Oh yeah she's topped off with antifreeze ready for the cold. I did put the new transmission on unfortunately I didn't put something together right in the shifter area. So unfortunately I had to pull that transmission back out.
  17. #467
    Feb 2016
    Florida
    All right the hybrid transmission has been taken apart and I found out that the shift change holder mechanism is bent the reason why I wasn't able to go inn first and second only 3rd 4th 5th and reverse.
    And come to find out from looking up the number the transmission bell housing is a second gen Accord a18 bellhousing. So two areas have to be grinded down to clear the larger pressure plate for the A20.
    But other than that the main shafts both shaft just slide into place Integra gears 1 through 4 and A18 5th gear and bellhousing. Waiting on a throwout bearing from spec clutch before I swap it out. As far as the car running it runs pretty good I got some tapping coming from the valve cover area I may have a bent valve it's also time to adjust valve lash so that's it for now.
  18. #468
    Whats you clutch choice? this EDIT: Clutchnet Green I have always sucked and now its just getting worse as far as shifting and hanging up. I swear I need just go back to stock.
  19. #469
    Feb 2016
    Florida
    Whats you clutch choice? this Clutchmaster Green I have always sucked and now its just getting worse as far as shifting and hanging up. I swear I need just go back to stock.
    It's making a chirping squealing noise when I first take off and I noticed the throwout bearing is wore out
  20. #470
    Feb 2016
    Florida
    I gave up on searching for the rear tokicos everyone is discontinued. So I went with these eBay special KYB shocks for the rear. To go with my H&R Springs and Cheddars Auto rear top hats.
  21. #471
    Good find. Let us know how it rides.
  22. #472
    Feb 2016
    Florida
    Rides like a dream lol. Way better than stock
  23. #473
    Cool man.
    The stock shocks valving was always terrible and the cheap aftermarket replacements are usually worse.
  24. #474
    Feb 2016
    Florida
    Junkyard gold .
  25. #475
    Weigh those out compared to the Drum setup...I wonder if its less weight.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
