Page 23 of 25 FirstFirst ... 1319202122232425 LastLast
Results 551 to 575 of 616
  1. #551
    Updates coming soon
    Pistons looking good man! Forged?
  2. #552
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Unfortunately not their Volkswagen turbo piston 82.75 mm with 21 mm wrist pin
  3. #553
    Feb 2016
    Florida
    I did put them on the scale and they weigh exactly the same. Should the valve recesses be on the exhaust side?
  4. #554
    Feb 2016
    Florida
    Decrease the block honed the cylinders prepped ready for primer and paint.
  5. #555
    I think that dish in the pistons look like Direct injection pistons. Do you think the compression will come out to low?
  6. #556
    Feb 2016
    Florida
    I'm really not too worried about the compression coming out low
  7. #557
    Feb 2016
    Florida
    Blocks painted starting to reassemble
  8. #558
    Feb 2016
    Florida
    Turbo feed and oil pan prepped. Getting closer and closer
    And Copperhead gasket
  9. #559
    Feb 2016
    Florida
    And here's my YouTube channel if you haven't already subscribed.
    https://youtu.be/z3HLrjR_NsA
    Last edited by Oldblueaccord; 04-30-2023 at 06:39 PM. Reason: imbedded video make it pro like
  10. #560
    A20 copper head gasket? NAW NAW....when this come out?
  11. #561
    Feb 2016
    Florida
    You can go to the website and search a20a3 and it's in there you can order them
  12. #562
    Feb 2016
    Florida
  13. #563
    Some one with a turbo needs one I cant remember at this point...I didnt think they would make them.
  14. #564
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    That's was me or t89. The problem we have is the bore size. They didn't make 84mm ones a while ago and a MLS is what I was after.
  15. #565
    Ah ok there you go...understood.
  16. #566
    Can't you cut them?
  17. #567
    Feb 2012
    89/accord/lxi
    Can't you cut them?
    I mean, sure, but I would like my headgasket to be exact if possible. It's not that they didn't make them at one point. Bobafett had a couple made by then, so it's definitely possible.
  18. #568
    Feb 2016
    Florida
    Looking like a pretty good fit everything clears.
  19. #569
    Feb 2016
    Florida
    Last one in stock huge shout out and thank you to the sales department at Golden Eagle
  20. #570
    Damn they look near zero deck!
    How did you figure this one out?!!?
  21. #571
    Feb 2016
    Florida
    Many years of research
  22. #572
    Feb 2012
    89/accord/lxi
    When the grasshopper becomes the master
  23. #573
    Feb 2016
    Florida
    Lol yes sir
  24. #574
    Feb 2016
    Florida
    Part numbers B18 I beam rods. https://www.ebay.com/itm/20400198810...mis&media=COPY
    Volkswagen GTI turbo Pistons 2.0 oversized piston. https://www.ebay.com/itm/14242129626...mis&media=COPY
    Pistons did require modification grinding on the inside for the rods to clear
  25. #575
    Are these dimensionally the same as an 83mm b series? How come you choose these over a turbo b series piston? Cost? Availability?
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
