Page 21 of 25 FirstFirst ... 11171819202122232425 LastLast
Results 501 to 525 of 617
  1. #501
    Alright so I am going to wait to make sure these ball joints fit this time. curious if the other Rockauto brands fit or if Mevotech was just selling the wrong balljoint...
  2. #502
    I google searched the part number and using the Unusual Activity Detected - Free Shipping on Orders Over $99 at Summit Racing Summit racing they list the applications. There are alot. Might get it local and cheaper is its correct.
    Make: ACURA
    Model: CL
    Submodel: BASE
    Beginning Year: 2002
    Ending Year: 2003
    Drivetrain: FWD
    Ball Joint Position: Rear
    Application Notes: Position: Rear. BALLJOINT
    Quote right off mevo website.
    Where are Mevotech parts manufactured?
    All Mevotech parts are Engineered in Canada and designed in-house in our North America headquarters. With Mevotech you'll never get reboxed parts from other manufacturers – you'll just get the best, original Mevotech parts.
    End quote.
  3. #503
    Thanks for searching that on Summit's unusual activity detector, that indeed does look like some unusual activity
  4. #504
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    here's the part number for mevotech should be a nice tight press-fit Click image for larger version.
    I haven't studied the control arm yet but which way does the ball joint go in picture one or picture two.
    1Click image for larger version.
    2Click image for larger version.
    Edit picture one is the correct positionClick image for larger version.
  5. #505
    Yes ill take the third pic for 50$ Alex!
    Its a ball joint used on lots of Honda/Acura type cars according to the Summit page so makes sense to use a part you could get anywhere.
  6. #506
    I just ordered the same rear set but of control arms
    FYI. I tried ordering some Mevotech control arms from Summit. They list them on their site, but they don't stock them. Once you order, they refer the order over to Mevotech for fulfillment. Basically, they're always on back order, but they don't tell you this until AFTER you pay for the order. Then you get to wait...
  8. #508
    They were in stock on rockauto, at least a couple weeks ago... just don't get the ball joints smh
  9. #509
    Feb 2016
    Florida
    Time for a long-overdue update. winter is basically Over and it's time for me to get to work on this thing. Recap I acquired a Sei rear disc conversion. Several days before ready to do the installation. a chain reactions of breakdowns went down. Some what, completely making me lose interest. as multiple radiators and alternators going out. 3 out of 4 tires getting destroyed. So I just been kind of laying low taking it easy saving little Parts here in there. More updates will be coming real soon
    So I've been staying pretty busy making B18 swap harness OBD1 harnesses, coil on plug harnesses and fuel pump relay kits to try to keep me motivated.
  10. #510
    Feb 2016
    Florida
  11. #511
    The brakes look exciting!
  12. #512
    Feb 2016
    Florida
    I'm excited to put them on lol
  13. #513
    See, nobody here cares about turbos or coil on plug here, at 3geez we only care about rear disk brakes.
    Your harnesses looks too similar to the one I am going to have to make for my buddy that's going from an obd2 b18 engine harness to an obd0 car, to an obd1 ecu. When does a mfer just go standalone?
  14. #514
    Feb 2016
    Florida
    I know right lol
  15. #515
    Feb 2016
    Florida
    I forgot to mention that my cheap dual eBay half size radiator finally went out. I had pretty good luck with it so we're going to try this cheap eBay triple core one now. With the OBD1 a12 reverse-trigger fan relay bypassing the fan control timer and fan switch. Click image for larger version.
  16. #516
    That Florida water eats radiators.
    With rads you want Aluminum thats a plus but the big thing is 1.250" tubes. Better heat transfer and stronger to run more pressure if you have too.
    That fan deal looks really trick. Is it a PWM controller? There usually really expensive.
  17. #517
    Feb 2016
    Florida
    On the fan my demon 2 Neptune RTP ECU software there's fan radiator control option it allows me to set the temperature I want the fans to come on and off. With pin A12 of the OBD1 FANC acts as a ground trigger. And that goes to a reversed ground trigger relay setup
  18. #518
    Yeah its easier on relays to switch the ground and less electrical noise with DC.
  19. #519
    Feb 2016
    Florida
    Yes sir
  20. #520
    Feb 2016
    Florida
    Upper control arm bushings ball joints and lower front ball joints ready for installation.
  21. #521
    Nolathane nice! you got them here stateside?
    Your gonna like that negative camber with those arms!
  22. #522
    Feb 2016
    Florida
    Yeah I got the bushings from eBay. Nolathane REV042.0020 Front Control Arm Bushing; Fits Honda Prelude 83-87 | eBay
  23. #523
    Curious how those bushing work and if you reuse the long metal sleeve with the stock bolt etc?
    Fill us in when your done with it.
  24. #524
    Feb 2016
    Florida
    Yes I first pushed out the long metal sleeved knocked out both ends of each bushing. The new bushings have to be cut down approximately half inch each side for them to completely go into the control arm. And then reinserted the metal sleeve
  25. #525
    Those bushings are tricky. I've bugged up more than my share trying to install them.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
