Page 6 of 25 FirstFirst ... 234567891016 ... LastLast
Results 126 to 150 of 617
  1. #126
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    we share a similar story. My mom bought one new back in 1988. it was my first car but she had an automatic carb. I bought mine right out of high school 10 years ago and now im proud to say its one of the fastest accords on the site. glad to see other people working on our cars. like i say old accords just get faster.
    Yes sir. labor of love
  2. #127
    Feb 2016
    Florida
    More parts inn oil catch can setup. Block plug and transmission installed
ID:	7752   Click image for larger version.
ID:	7753   Click image for larger version.
ID:	7754   Click image for larger version.
  3. #128
    LX User knifemind's Avatar
    Mar 2008
    88 dx & 85 Lude
    Montana
    Is that plug off the shelf? for a B or D series perhaps?
  4. #129
    Feb 2016
    Florida
    Quote Originally Posted by knifemind View Post
    D series block plug from go-Auto Works. You have to cut off the first o-ring section. And use a fatter bigger o-ring
  5. #130
    Feb 2016
    Florida
    Arp head studs installed. Getting closer
  6. #131
    Ayeee glad someone else did the block plug also.
  7. #132
    Feb 2016
    Florida
    Yes sir it's a must-have clears up a lot of space back there for other things like your engine oil cooler sandwich plate and turbo oil feed lines
  8. #133
    yupppp. Im still suprised nobody did that before me(at least that i was aware of) it makes everything so much nicer. did you cut the return off of the oil pan?
  9. #134
    Feb 2016
    Florida
    Not yet wasn't 100% sure what to do with it. cut it plug it ?
  10. #135
    I cut it off then had my welder weld the hole shut.
  11. #136
    Feb 2016
    Florida
    Cool man thanks for the info
  12. #137
    Feb 2016
    Florida
    Oil pump O-rings replaced and more parts inn passenger side CV axle ,lower control arm and timing tensioner pulley
ID:	7759   Click image for larger version.
ID:	7760   Click image for larger version.
  13. #138
    Feb 2016
    Florida
    Turbo oil feed fittings and line installed
ID:	7762   Click image for larger version.
ID:	7763   Click image for larger version.
  14. #139
    Feb 2016
    Florida
    More parts extended intake manifold studs and crankshaft oil seal
  15. #140
    Hell yea extended intake studs!
  16. #141
    Feb 2016
    Florida
    Yes sir. I'm trying to get it right this time
  17. #142
    Feb 2016
    Florida
    Water pump, oil pump, belt tensioner, alternator front lower ball joints installed. EGR valve removed plugged. And I was only able to find a distributor piece from a head from a carbureted model. Which only has one ear instead of two .don't know if it's going to be compatible with the OBD1 distributor adapter plate
ID:	7769   Click image for larger version.
ID:	7770   Click image for larger version.
ID:	7771   Click image for larger version.
  18. #143
    Feb 2016
    Florida
    Thermal throttle body gasket installed with extended stainless studs
  19. #144
    That a oem b16 intake?
  20. #145
    Feb 2016
    Florida
    Stock a20
  21. #146
    Feb 2016
    Florida
    All brittle and broken connections repaired and retaped wire harness
  22. #147
    Feb 2016
    Florida
    Radiator hoses dressed up
  23. #148
    best thing you can do especially if you get rid of useless wires
  24. #149
    Feb 2016
    Florida
    Yes sir and I like to get rid of majority of the black box components as I can
  25. #150
    Feb 2016
    Florida
    New intake and exhaust valves. Now if I can find some exhaust valve spring retainers I might be able to put the head back together someday
ID:	7785   Click image for larger version.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
