Page 10 of 25 FirstFirst ... 6789101112131420 ... LastLast
Results 226 to 250 of 617
  1. #226
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Well work has picked up a little bit so I was able to purchase a couple of things. Got my jumper harness ready to go. Got a lot of vibration from a bad wheel bearing time to replace them. And I'm going to grind down the ball on this Honda Civic short throw shifter and see how it works
ID:	8060   Click image for larger version.
ID:	8061   Click image for larger version.
ID:	8062   Click image for larger version.
ID:	8063   Click image for larger version.
  2. #227
    Hell yea! Progress
  3. #228
    Feb 2016
    Florida
    Hell yea! Progress
    yes sir. Don't count me out yet this project is just beginning. Distributor adapter plate from Oddball adapters.com
  4. #229
    LX User rushell's Avatar
    Oct 2012
    i never knew about this site i will go obd1 this summer
  5. #230
    Feb 2016
    Florida
    Quote Originally Posted by rushell View Post
    yeah man it came out a couple months ago. you can also purchase the front and rear motor mount plates that hold the energy suspension GM transmission motor mount
  6. #231
    Im glad Chris still makes these plates. I was one of the first ones here to go plateless and it got people talking about a bolt on adaptor. long story short the person helping just disappeared and Chris took over and now more and more cars can go OBD1
    Feb 2016
    Florida
    Big jump. Got the demon v2 Neptune RTP po6 package from haMotorsports. Added boost by gear and Bluetooth
ID:	8113   Click image for larger version.
ID:	8114   Click image for larger version.
ID:	8115   Click image for larger version.
  8. #233
    Feb 2016
    Florida
    Front wheel bearings , slotted drilled rotors, stainless brake lines installed. What a day!!!
ID:	8130   Click image for larger version.
ID:	8131   Click image for larger version.
ID:	8132   Click image for larger version.
ID:	8133   Click image for larger version.
  9. #234
    this is why i do everything in my suspension when it take it out. ball joints(moog), bushings(poly) one time and thats it, new rotors and pads if its time because its just make it easier down the road.
    Feb 2016
    Florida
    a couple more parts for the collection.innovate MTX-L afr kit, volt gauge, adjustable fuel pressure regulator. preparing for big updates soon
ID:	8180   Click image for larger version.
ID:	8181   Click image for larger version.
ID:	8182   Click image for larger version.
  11. #236
    dont need a volt gauge if you gonna have the bluetooth haha. But great to see you are still making progress man! you are getting close to having everything you need!
  12. #237
    Feb 2016
    Florida
    Got the volt gauge to replace the fake air fuel ratio gauge since I got a real one
ID:	8195   Click image for larger version.
  13. #238
    Feb 2016
    Florida
    Shielded wire and wideband wiring ran. And made a plate to hold the OBD1 ECU
ID:	8237   Click image for larger version.
  14. #239
    Feb 2016
    Florida
    Distributor plate and distributor installed wiring is finished
ID:	8241   Click image for larger version.
ID:	8242   Click image for larger version.
  15. #240
    Feb 2016
    Florida
    It runs. YouTube obd1 start up runs like crap
  16. #241
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Nice work bro
    Sent from my SM-N920P using Tapatalk
  17. #242
    Feb 2016
    Florida
    Nice work bro
    Thanks man . I'm working on it right now trying to figure out this Neptune RTP stuff
  18. #243
    Feb 2012
    89/accord/lxi
    Yeah it can be a bit of a learning curve. I only know the basics. I let my tuner do the hard stuff lol
  19. #244
    Feb 2016
    Florida
    It's very frustrating I'm ready to pull my hair out LOL
  20. #245
    Thats why i stay mostly stock!
    Good luck with it youll get it.
    Car will run from 15.5 to like 10 AFR without much noticeably,short term, running problems. Just my experience.
  21. #246
    Feb 2016
    Florida
    It's running a lot better now I'm starting to learn how to use Neptune. Only problem right now is my innovate MTX - l I think it may have a faulty sensor either shows 22.4 or 7.4
  22. #247
    run the ground to it straight to the battery. Its sensitive to ground off set. all DC is.
    Follow the set up instructions to the letter ,free air all that jazz.
    I have had zero luck with them as far as tech support so good luck. My gauge is .2 off what the computer says and always has been.
  23. #248
    Feb 2016
    Florida
    I will try that mine is grounded directly into the ECU pin a26. And my computer says it's off by .2 too.
  24. #249
    Feb 2016
    Florida
    Grounded the gauge to the negative side of the battery now it's working great thanks oldblueAccord
ID:	8256   Click image for larger version.
ID:	8257   Click image for larger version.
  25. #250
    Good deal.
    Get some gas to that thing shes pretty damn lean.
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
