Page 11 of 25 FirstFirst ... 78910111213141521 ... LastLast
Results 251 to 275 of 617
  1. #251
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Now that the car is running pretty good but at idle the gauge is everywhere on the air fuel ratio. Any ideas? do I need to change the way it's powered right now it's powered from pin A25 on the obd1 ECU . And the yellow wire hooked up to pin D14
  2. #252
    Feb 2016
    Florida
    Here's my O2 settings Neptune don't know if I have them right yet
ID:	8259   Click image for larger version.
  3. #253
    Are you using the wideband as your only O2 sensor. So your trying to simulate the narrow band output im am guessing?
    Not sure about this the setting have got to be on the internets someplace.
    if your really lean like you showed the AFR will be inaccurate or all over the place. The closer you get to 14.7 steady state the easier it is to tune.
    You got your fuel pressure steady like at 40 psi. Thats a pretty good base pressure on a Honda. Unless you got some kinda crazy injector set up.
  4. #254
    Feb 2016
    Florida
    Yes I'm trying to run the wideband as my only O2 sensor. It's not running lean anymore now it's showing its running around 10 and all over the place. stock injectors stock fuel pressure regulator. The signals wired into the yellow wire wideband wire should it be wired into the brown narrowband signal?
  5. #255
    That im not sure on that one they might need to be combined. I never ran one that way.
    Go thru the prints again or ill try to pull them here in a minute and read thru it and see.
    Not too sure about the erractic runing. maybe run it open loop with out the O2 senosr and just see if the maps are even close at a few RPM spots. Let the wideband log what your seeing.
    EDIT:
    Sound close?
    Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2)
    can be connected to the analog inputs of other devices such as data
    loggers or ECUs. If either one or both of these wires are not being used
    isolate and tape the wire(s) out of the way. The default analog outputs
    are as follows: Analog output one (yellow) is 0V = 7.35 AFR and 5V =
    22.39 AFR. Analog output two (brown) is 1.1V = 14 AFR and .1V = 15
    AFR
    yellow and brow scale different.
  6. #256
    Feb 2016
    Florida
    EDIT:
    Sound close?
    AFR
    Thanks for all the help I am going to try to switch to the brown wiring and do a lot of testing to see if I can figure it out
  7. #257
    yeah brown for the simulated and yellow for the gauge sound right to me. Im thinking the gauge is 0-5v.
  8. #258
    Feb 2016
    Florida
    tested the brown no luck with that. Inspected all my wiring. Reading a little on line about it and someone grounded the dimmer switch separate then the Gage. i did that recalibrated and now we're in business victory
  9. #259
    Feb 2016
    Florida
    To the next puzzle which would be Code 17 vss. Neptune it doesn't show that this is a error code the car is not running in limp mode. It just shows I have no VSS signal without that I can't enable two step or boost by gear.
  10. #260
  11. #261
    glad you got it figured out!! Good what year is your car again? I know for the 86-87 to get a vss you have to add a resistor in the cluster. There is a writeup on it here.
    also you wont be able to run boost by gear because our transmissions dont have a sensor to let the ecu what gear is what. Just a vss
  12. #262
    Feb 2016
    Florida
    Yes 86. Now I just need the resistor to try that out. I heard I can get a cluster from a 89 to get a VSS signal
  13. #263
    Here
  14. #264
    Feb 2016
    Florida
    Here
    Where can I get the 6K resistor only been able to find 5.4 or 6.8
  15. #265
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    RadioShack if there's one still open near you may be a Fry's Electronics also
    Sent from my SM-N920P using Tapatalk
  16. #266
    Feb 2016
    Florida
    Radio Shack's in my area I'll check that out
  17. #267
    Feb 2012
    89/accord/lxi
    Yeah its would be a good time to make a list stuff you need your you can use later because they are going out of business in the next month or so
  18. #268
    Feb 2016
    Florida
    I installed adjustable fuel pressure regulator. Bumped it up from 38 to 40 the car is running better and better everyday
ID:	8275   Click image for larger version.
  19. #269
    Feb 2016
    Florida
    I didn't know that I'll hit them up first thing in the morning thanks
  20. #270
    Higher the fuel pressure the better the spray pattern.
  21. #271
    Feb 2016
    Florida
    Made a jumper for pin D4 scs- service check signal /timing jumper.and obdo to obd1 map sensor plug. And on the resistors my local radio shack is closed! Order some from eBay.to be continued
ID:	8279   Click image for larger version.
  22. #272
    Feb 2016
    Florida
    3k resistors
  23. #273
    i did that didnt work. save your self the hassle an get a 89 accord cluster. your just wasting your time.
    Feb 2016
    Florida
    I'll try that before I go hacking into my harness
  25. #275
    Feb 2012
    89/accord/lxi
    I may have a cluster. Ill check in the am
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
