Page 16 of 25 FirstFirst ... 6121314151617181920 ... LastLast
Results 376 to 400 of 616
  1. #376
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Quote Originally Posted by rushell View Post
    pm me when u get a chance
    Pm sent
  2. #377
    Feb 2016
    Florida
    worked on preparing the intake manifold today.got the throttle body Port matched.two holes drilled ran out of cutting wheels still got a little cleaning up on the flange to do to be continued.Click image for larger version.
ID:	8923Click image for larger version.
ID:	8924Click image for larger version.
  3. #378
    Feb 2016
    Florida
ID:	8930Click image for larger version.
ID:	8931Click image for larger version.
ID:	8932 got the intake manifold installed and it's running I should have did this upgrade a long time ago
  4. #379
    Feb 2016
    Florida
    decided it was time to pull my engine harness and completely rebuild it and my cam gear came in todayClick image for larger version.
ID:	8958Click image for larger version.
  5. #380
    Feb 2016
    Florida
ID:	8960Click image for larger version.
  6. #381
    Sexy!
  7. #382
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Doing work son
    Sent from my SM-N950U using Tapatalk
  8. #383
    Feb 2016
    Florida
    Doing work son
    Yes sir it's getting there
  9. #384
    Feb 2016
    Florida
ID:	8972Click image for larger version.
ID:	8973Click image for larger version.
ID:	8974 i got a cup holder
  10. #385
    Nice!
  11. #386
    Feb 2016
    Florida
    Received my mild Street turbo cam today. I don't know if anybody knew to check the clearance section and yes I know I could have saved 80 bucks purchasing from Delta but you know oh wellClick image for larger version.
ID:	9014Click image for larger version.
ID:	9015Click image for larger version.
  12. #387
    '85 lude
    houston
    Is that what that was? the girl on the phone couldn't give me any real info. just duration and cam lift without rocker ratio and I've not been able to be 100% sure what that is so i can compare cams.
    Why are all these camshaft people's website such ass :/
    Can you post the spec sheet for it?
  13. #388
    Feb 2016
    Florida
    Quote Originally Posted by night View Post
    they had two different ones to pick from and the one I got was recommended for Mild Street or Turbo application. I requested a timing card but never received one the way they were keeping it secret makes me think it might be a bisimoto 1.2 turbo cam. We will see. they couldn't give me too much information on it either other that it's like a stock cam but .020 more lift on the intake side with 6 degrees duration and .029 more lift and 10 degrees on the exhaust side.
  14. #389
    You can get a degree wheel and run it around and plot it your self. Just needs to be installed. I m sure there some vids on "how to degree in a cam" or find the center line.
  15. #390
    '85 lude
    houston
    These are the numbers she gave me on those 2 cams a month ago..
    277in / 290ex - 226/240 dur
    277in / 277ex - 240/240 dur
    Except my stock cam i measured at 269 lift so i didn't see the point.
  16. #391
    Feb 2016
    Florida
    Swapped in the new cam got my distributor key replacement and replace the distributor o-ring and cleaned it up a little bitClick image for larger version.
ID:	9042Click image for larger version.
ID:	9043Click image for larger version.
ID:	9044Click image for larger version.
ID:	9045Click image for larger version.
  17. #392
    Feb 2016
    Florida
    Finally received my Cheddars Auto shifter bushings and Birdcage bushing. And it sure does make a big difference replacing them old wore-out bushings.https://m.imgur.com/a/5ISeWtz
  18. #393
    Feb 2016
    Florida
    Starting to work on the suspension went ahead and modify these Honda Civic top hats added grade 12.5 studs and redrilled Click image for larger version.
ID:	9125 Click image for larger version.
ID:	9126 Click image for larger version.
  19. #394
    B0CKS's Avatar
    Jul 2016
    1988 DX Coupe
    Detroit MI
    Niiiiiiiiiiiiiiiice, saving that tip for later!
    [SIGPIC]
  20. #395
    Feb 2016
    Florida
    Quote Originally Posted by B0CKS View Post
    Yeah man for 42 bucks for everything. I'm pretty happy how they turned out Click image for larger version.
  21. #396
    Feb 2016
    Florida
    Retrofit lights Click image for larger version.
ID:	9153 Click image for larger version.
ID:	9154 Click image for larger version.
ID:	9155 Click image for larger version.
  22. #397
    Oooooooooooo! I like!
  23. #398
    Feb 2016
    Florida
    Thanks boss I'll try to get some better pictures once everything's installed
  24. #399
    '85 lude
    houston
    how low is your car that you need top hats
  25. #400
    Feb 2016
    Florida
    Only a couple inches the top hats save the shocks by preventing them from bottoming out allowing the shock body to travel inside the top hat
  1. JohnBoy's Turbo build
  2. A20A3 Turbo Build
  3. Turbo build, engine pics
  4. turbo build up A20
  5. turbo build up A20
Tags for this Thread
