Yes back with a problem. I've went through all my problems i think i've narrowed this down to the electrical. I opened the distributor up and found it with reddish dust a sign of a bad bearing from what i've read. My car has been acting awful lately. When get up to around 50 mph my idle will all of a sudden drop like it lost power then when I give it gas it will pick up again. I have a feeling eventually it will die in the middle of the highway leaving me stranded. I have a hunch its the distributor. Was going to follow Snoozes lazy distributor overhaul when I was thinking that this could possibly be a timing problem. I have no timing light so if I remove the distributor I and clean it out form what snoozes thread said you need to reset the timing. So i'm in a predicament. I know a local junkyard has an 89 lxi like mine but would it have the same dizzy? Also is there a way to do this overhaul and not reset timing? Please help 3geezers once again i'm going crazy.
