Page 3 of 3 FirstFirst 123
Results 51 to 54 of 54
Thread: bscanlan' Hatch Build - The Sequel
  1. #51
    bscanlan's Avatar
    Jul 2012
    1988 Accord LXi Coupe
    Amherst, Ohio
    Re: bscanlan' Hatch Build - The Sequel
    Donít know if my engine install pics show it, but utilizing the Cheddas traction bar, which eliminates the center trans mount and the front (engine) bell mount, causes the engine to sag rather considerably on the passenger side. This stresses the driverís side mount (I also have the Cheddas mount with urethane bushing) more than I am comfortable with. So I fired up the design software and 3D-printed a prototype trans mount that will utilize the auto mount from the passenger side wheel well. Lucky that this is an auto-to-manual (donít say it Snooz) swap, leaving me that point for a 4th mount. It will utilize the same rubber trans mount that the auto uses in the same location. Also, it attaches where the engine hanger bolts to the trans so I figure thatís a pretty solid point. Itís in plastic right now, but will get it made in the machine shop at school next week or so. I am excited to see if this secures things a bit.
    1989 LXi Hatchback - Napster
    1989 LXi Sedan - sold 😒
    1988 LXi Coupe - Old Skool
    2019 Subaru Forester Touring - DD
  2. #52
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Hi, excellent work you're doing first of all! Regarding your flywheel though, I'm wondering if you milled all three windows larger or just the one pictured? You probably did all 3 (or some other balancing), but just in case it was only the one, then you could very likely have introduced an imbalance large enough to cause noticeable vibration and lead to early failure of bearings or even fatigue failure of the crank. I mention it because judging by that picture it appears to be a rather sizeable lump you milled away.
    Link to my 3geez garage
  3. #53
    bscanlan's Avatar
    Jul 2012
    Amherst, Ohio
    Thanks Dane! Indeed I milled the same amount from all 3 ďwindowsĒ. I needed that in order for the pressure plate to seat; to alleviate my issue. I do realize that the flywheel was balanced upon production, so I will just have to see what I did once sheís spinning.
  4. #54
    Jan 2003
    Denmark/Europe
    Excellent, I'm sure it will run smoothly then. Looking forward to see the build continue!
  1. 87roach's 1987 S Hatch Build
    By 87roach in forum Project Central
    Last Post: 05-13-2020, 12:07 PM
  2. King Peetis's 88 Hatch Build Thread
    By King Peetis in forum Project Central
    Last Post: 06-29-2011, 11:03 AM
  3. Mark's 89 Hatch Build Thread
    By markmdz89hatch in forum Project Central
    Last Post: 04-28-2011, 04:55 PM
  4. 87roach's 1987 S Hatch Build
    By 87roach in forum Classic Honda Pics & Videos
    Last Post: 09-20-2009, 09:44 AM
  5. Bglad420's 88 Hatch Build Thread
    By Bglad420 in forum Project Central
    Last Post: 02-25-2007, 02:54 PM
VigLink badge
