My accord has this problem that it won't idle. Start up is fine, runs at 2500 rpm, but then after warm up it will not idle. If i give it throttle it will run but as soon
as i come to a stop, it will die if i don't continuosly give it throttle. I've read where the primary slow mixture solenoid valve located on the back of the carb will
shut the car down by blocking the idle circuit via a plunger. I disconnected it and tested it by turning ignition key to start, and the plunger did not retract. I tried
to access the switch but could not test further b/c could not open the connector. My question is for anyone who knows, is this cutoff solenoid absolutely necessary?
What is i just fill the port where it connects with silicone--- or some other material??? What are the possible complications aside from the engine running on a bit
on shut down--- thankks for any information on this
