Results 1 to 10 of 10
Thread: My 1985 is MELTING!!!
    Jun 2016
    My 1985 honda accord LX burnt out the neutral safety switch as well as the whole area under the shifter....it got really hot and melted the plastic...it made the shifter unable to switch gears. I replaced the neutral safety switch and it still gets hot. does anyone know the problem?
    Jun 2016
    My 1985 honda accord is Melting!
    Re: My 1985 is MELTING!!!
    No electrical component should get so hot they melt things, make sure that all your fuses are the correct sizes.
    I don't have any answer as to what is causing it though.
    Your starter solenoid could be drawing too much power or the wiring between it and the starter is damaged and shorting...
    Also on the 86-89 it powers the reverse lights so check that also
    Re: My 1985 honda accord is Melting!
    I thought I replied to this... Most likely causes:
    1)Starter solenoid drawing two much current.
    2)Reverse lights drawing too much current.
    3)Short in one of the above circuits.
    Have you noticed anything electrical quit working since this problem arose?
    Sorry but this post made me think of this...
    https://youtu.be/9TnGjq9mWSI#t=3m12s
    Scroll to 3m12s for mobile users...
    Jun 2016
    Quote Originally Posted by POS carb View Post
    should I replace the starter solenoid and go from there?
    You should check the current draw and replace parts accordingly.
    Also look out for any corroded connectors that cause too much resistance and heat in the loom. I dab all connectors with dielectric grease to prevent corrosion. Physical damage to a loom can cause current to go places it shouldn't causing melting. Finally, if the heat shields for the exhaust system have disappeared, that can cause insulation in the loom to melt.
    Merging dupe threads.
  1. my control switch box is melting!
    By danny nr crew in forum 3geez Accords
    Last Post: 11-03-2013, 04:53 PM
  2. would it fit my 1985?
    By ajg1904 in forum 2geez Accords
    Last Post: 11-24-2008, 10:40 AM
  3. 1985 SEi
    By MTTRACE in forum 2geez Accords
    Last Post: 02-03-2003, 06:27 PM
VigLink badge
