Results 1 to 21 of 21
Thread: Possibly a stupid question...
    LX User 88accordlxcarb's Avatar
    Jan 2003
    '88 Accord LX(carb)/'92 Infiniti G20/'00 Infiniti I30/'88 Oldsmobile Cutlass Ciera(286,000 miles), 2004 VW Passat, Golf Cart...
    Middle Georgia
    Ok this is a newbie question...
    Dont get the wrong idea, but... My 88' Accord LX has around 185,000 miles on it. I've done a good bit of work on the head(plus a new with new head gasket. Cam and valves are stock), its been shaved a little(because it had to be). New plugs, flipped lid, rest is stock.
    Will anything happen if i try to reach the max speeds? I mean shifting at redline and then flooring it till it redlines at around 120(?). Will that do any damage, or even excessive wear and tear on this old engine? I would like to be able to drive it till at least 210,000 miles. I wont be doing it often.
    What about gunning it, for example not shifting till redline? I never drive like this, well mainly because i was afraid of 'blowing' my engine.
    Any advice?
    Jason
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    3geez motors are bulli proof!
    go for it... we all race alot
    Travis
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    These engines put up with everything we throw at it, except for a couple people that try new things to make more hp and blow it. Not naming any names though. It won't hurt it if you try to max it out though.
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    only possible damage
    is to your wallet for speeding..but please check tires before going for max speeds
    1988 Honda Prelude 2.0Si
    Santa Rosa, Ca
    its good to redline your engine every once in a while, it helps burn out possible carbon build-ups. just make sure that your oil doesn't ever get too dirty, that could accelerate wear..
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    Re: Possibly a stupid question...
    i drive that way every day, lol, and i've never had any problems. our engines usually last well into the 200K miles. mine has 219k, it might've rolled over to 220K miles today, im' not sure, but it's way close to doing so if it hasn't yet.
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    2008 CBR 600RR -- 1995 Toyota Supra NA -- 2013 Nissan Frontier Pro-4x
    Jan 2003
    Middle Georgia
    Ok sweet! :smokin:
    thanks
    Jason
    SEi User od2681's Avatar
    2003 Infiniti G35 sedan
    Houston Tx
    dude regular tune ups and oil changes...you can try firin bullets at hte engine and it still wouldnt get damaged.....
    LXi User 89accordboi's Avatar
    '93 Integra
    portland
    oh i make sure i never have carbon build-ups :pimp:
    1986 Honda Accord Lx-i w/FI
    Pensacola FL
    you guys wanna hear a car with alot of mileage, mine has 271K and its still runnin like a champ
    :pimp:
    Before you get near redline make sure the car is warmed up, and dont go too much into the redline either
    accord HB ( metallic green)
    B.C Chilliwack
    I agree they take abuse, my old carbed engine had 350,000km on it before it finnaly died, and I carried it to redline often. Now hopefully my new one will take as much shit and abuse, So far it is.
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    2.0Si User Grant2k's Avatar
    just going to redline shouldn't hurt it because the reason the redline is there is to be a measurment of roughly how much the engine can take before damage occurs. but like you said, don;t make a habit of it.
    a pile of lawn ornaments
    Newtown, CT
    the engine will deal well with the "abuse". It's not atually abuse b/c you're not hurting anything (in the engine at least.)
    but like njpeter said, and many "speeders" always forget to take into consideration, please for the love of everything holy, please check ur tires. Also, remember ur engine is bulletproof, but at speeds of 100+ you never know what a stock 200Kmi. suspension can be doing.
    -Mark D.
    Jan 2003
    Middle Georgia
    Yeah, my tires are inflated by what it says on that little sticker.
    88 honda accord lxi
    louisiana
    my 88lxi has 250k and i run it hard every day. i also drive
    300 miles towork every week going at least 80.the only problem
    i had was my hood opened goin 80 and smashed my windsheild
    and sun roof.so allways check ur hood.
    88lxi under construction
    01 integra wheels
    New Jersey
    that was a close one eh...
    hood fly ups normally result in a major crash or rollover..a very lucky break..good ide to check both the hood latch AND the safty catch if you routinely drive at high speeds
    your tires might be inflated corrctly, but that doesn't mean they can handle the speed. tires are speed rated which means that they are only garaunteed to perform correctly up to a certain predetermined speed. i bet the tires you have aren't even garaunteed up to 100. be careful.
    1994 Honda Accord, saving up for 2004 Subaru WRX
    Massachusetts
    i've pushed my car to 110mph on spiked snows.. the only thing that happened was the loudest tire humm i've ever heard. then again they were at reccomended PSI and i do have a new suspension system.. make sure you do check that out.. 100+ on a soupy suspension can cause a date with a guard rail.
    I reccomend checking your balljoints before tackling this too, granted mine are new, but i've seen cars with old ones where just driving down the road causes them to fail. you dont want your wheels looking like the flying DElorian in Back To the Future two screaming down the road at 100+.
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
    PERFECT Maroon Interior
    Call or Contact Dan @ 1-617-893-8320 or E-mail at [email protected]
    Massachusetts
    also... very important to those with AUTOS... DON'T ABUSE THEM!!!.. pushing a stock auto over 100k to redline more than a few times can lead to MAJOR problems (ie, Bands, CLutch Packs, and general sludge from the old filter circulating back into the system. ) But, those with 5speeds can let em rip.
    ForSale!
    88Accord LX AUTO
    NEEDS:
    Transmission
    Tires
    Altinator
    Belts
    Battery
    I drive that way every day, so far nothing major. I've never gotten a ticket either. For example, I did about 90 to 100 on the freeway yesterday for miles and I was fine. Just be sure you can handle driving at high speeds, and make sure you have both hands on the wheel. Don't ghetto ride it and be like "Word G I got one hand on the wheel."
  1. Stupid Question
    Last Post: 07-31-2004, 10:59 AM
  2. stupid question
    By igell in forum 3geez Accords
    Last Post: 04-21-2004, 01:33 PM
  3. Possibly stupid question... or good idea...?
    By RustyHo88 in forum Carburetor Tech
    Last Post: 09-12-2003, 02:22 PM
  4. stupid question but please help
    By juiquan in forum General Engine Swaps
    Last Post: 03-02-2003, 09:05 PM
  5. very stupid question to be asking
    By 3rdGenMartyr in forum 3geez Accords
    Last Post: 11-18-2002, 11:07 PM
