my car pulls to the right kinda hard, what coud cause this, prob bad alighnemt right?
it could be alot of things ! but i would check the alignment first !
MIKE
The alignment people will tell. It could be the tire pressure and/or tie-rods.
Rooz
Or it could mean your wheel is going to fall off :lol But I hope not
It could also be a slightly frozen/dragging brake caliper. Check the balljoints and tierods by jacking it up at that tire and check for both horizontal and vertical play. Play horizontally = tierods, play vertically = balljoints. If everything's ok though, then most likely it's an alignment
-Jared
Whenever you lower your car will usually start going to the right or left. Usually alignment does the job. When it doesn't then camber kits are needed for either the front or the back. I'd check into it.
That is not fun at all...sounds like a flat tire...and even looks like it. But when you get your spare and jack ready, just to find out that the nuts are looseOriginally posted by Jareds 89 LX-i
