Hello all,
I have found that the high idle does not properly work on this 1989 LX, the choke does not close. Because the vacuum choke piece does not seem to produce any vacuum with the lines removed, I believe that the rubber piece is ruptured, so I got a replacement for it. However I can not seem to successfully remove the old one, it looks like it is held with two phillips screws which are stuck in place. None of the 30 or so screwdrivers I have seems to be able to fit in the space without being on an angle which would strip the screw. Does anyone have a specific tool recommendation for removing this choke piece? I can get pictures if you don't know which piece I mean but it looks like this: OES Genuine Choke Diaphragm Fits: Honda Accord 89 88 87 86 1989 1988 1987 1986
Thank you for reading.
