for those who want to use PR mounts. i must warn u that the rear mount is badly designed. i recently literally tore out the mount out of the back cross membrane. so ofcourse i had to get a new one. the mount is strong.. but the way it is bolted down to the back cross membrane., it isnt very sturdy. i recently got it welded on cross membrane and is holding very nicely. i highly suggest that whoever does this kind of swap.. get jus the back mount bolted on and welded. as for the other mounts.. it is holding nicely.. but im still iffy about the passenger mount becuz it is being held by 10 and 12 bolts.. i remember 3 10 bolts and 3 12 bolts. ofcourse if it were size 16 bolts atleast then i wouldnt worry. but will my clutch and the parts i put in to the motor. it gets very scary when shifting to second or when dumping the clutch. there's a lot of jerking and pounding. i jus dont want to break something for driving my own car like i stole it and regret for racing so stupidly. but ofcourse it might be different with a stock motor. but even though, i still wouldnt trust it. as for everything else.. it's holding jus perfectly.., i jus hope the axles dont go out on me.
jon
