Results 1 to 12 of 12
Thread: grinds when i swithc to 2nd
    LXi User 89accordboi's Avatar
    Nov 2002
    '93 Integra
    portland
    Angry grinds when i swithc to 2nd
    ite when i switch to 2nd gear it always grinds if its like over 4,000 rpms, in the morning it doesnt grind though. i really hate the sound of it like when i have a friend with m ycar and im racing someone it sounds lame... any suggestions? thx
    Jan 2003
    87 Accord LX
    Well if you have a 5 speed it could be that your clutch is not aligned correctly. And if it is an auto check your fluid levels. But automatic transmissions love to start going bad when you have a car that is that old. Take it to the local transmission place and have them look at her don't let it go on any longer. I had the same problem and had to get my tranny rebuilt
    If it is broken then fix it. IF NOT LEAVE IT THE HELL ALONE
    Jan 2003
    87 Accord LX
    Try getting your tranny flushed and refilled first. If the fluid is black its burnt. If the fluid has metal in it your tranny is starting to come apart.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    if its low it might also gring and it could also be the syncro's
    a rebuild might be in order... but a nice LUDE tranny can be found for less...
    Travis
    1988starter
    Guest
    Try using one bottle of lucas MTL with your oil change it helped my syncros before I got the rebulid and I continue to use it today.
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    notice how now one said "yeah why dont you check this and look at this and then take off this and replace this" :lol you said "take it to a shop" :lol
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    Jul 2002
    89 Accord LX-i coupe, Auto
    Missouri
    i got a question. i have an automatic and sometimes when i shift gears in a short period of time, like when re-adjusting to get into a parking spot and i have to shift from drive to reverse to drive to park, or whatever, there will be a whining sound for a few seconds, or sometimes longer. any suggestions?
    "Turn off the television sets and eradicate the slander that says a black youth with a book is acting white." - Barack Obama
    Nov 2002
    '93 Integra
    portland
    :lol @ that.... socal3rdgen knows me well
    2.0Si User Blue Impact's Avatar
    93 Integra LS-S
    Oroville, CA (it's on some maps)
    Mine does that too if I shift quickly regardless of the rpm. I can't see anything that could be doing that since I just got the clutch replaced back in June. The only solution I found to not grinding it would be to granny-shift (shifting slowly and gently) into second.
    Quote Originally Posted by k-roy
    Street racing is for idiots.
    LX User Scotts88WhiteLX-i's Avatar
    Oct 2002
    88 Honda Accord LX-i Sedan
    Eugene,Oregon
    mine does it when i downshift into second....Cause sometime i have the stick to far left a little so it grids a lil bit.... is that normal????
    -Scott
    88ancient
    -Its not illegal until you get caught-
    Nov 2002
    '93 Integra
    portland
    i hate granny shifting, especially when im racing lol
    Jan 2003
    87 Accord LX
    I will mess with naything on my car except that damn auto tranny. Soon to be replaced with a 5 speed with a short throw shifter.
  1. Transmission Grinds consistenly into 2nd
    By BoogerBurns in forum 3geez Accords
    Last Post: 03-02-2010, 12:24 PM
  2. Grinds when shifting into reverse.
    By 86AccordLXSdn in forum 3geez Accords
    Last Post: 11-21-2007, 08:39 PM
  3. tranny grinds
    By ACE_14 in forum 3geez Accords
    Last Post: 05-02-2004, 07:32 PM
  4. reverse grinds
    By lightbulblxi in forum Classic Honda Community Chat
    Last Post: 10-28-2003, 06:14 PM
  5. m-tranny grinds into 3rd
    By johnwc723 in forum 3geez Accords
    Last Post: 02-28-2003, 08:28 PM
