Results 1 to 14 of 14
Thread: Hey Jim!!!!
    Jun 2002
    1988 HONDA ACCORD LX
    from ALASKA stationed in Korea
    Hey Jim!!!!
    I am interested in these wheels, I found them on tirerack.com
    ASA K3
    Size Selected
    17x7.5
    $125
    In Stock
    Recommended
    Tire Size
    205/40-17
    86 Honda Accord LXI HB 5-sp
    Central California
    Call them and ask what the offset is on the rims.
    Not sure if your performance driven, but www.whalentire.com does have some good deals and a some of their choices do list the weight of the rim, try not to go heavier than 18lbs. Personely I wouldn't go heavier than 16lbs.
    Jun 2002
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    How heavy are SI rims? I know they aren't the lightest but they are very light.
    Central California
    16lbs, nothing special, but at least their not heavier than the oem rims. And hopefully their cheap to buy.
    Now I d
    Mankato, Minnesota
    I already have them and I paid $50 for all for with tires. I just didn't know the weight of them for sure.
    Central California
    wow, congrats on your find. Well usually that price buys you some heavy ass junkyard rims. It's a understatement to say you did good. What tires are on them and what size of tire are they?
    Mankato, Minnesota
    they are BF goodrinch tires just stock size and I did get them from the junkyard. No scratches, no bends, no cracks. Just going to get them refinished hopefully if I can find someone to do them and put new clear or powder coat them.
    Jun 2002
    hey jim are these a good rim to put on my accord
    http://www.whalentire.com/wheeldetai...H40HMS&size=17
    Central California
    Are they good in what respect?
    They would look great on the car.
    But most all ARD rims are way to heavy, IMO.
    I did a post at the top of this section of the board where I posted some web sites that have master lists for rim weights.
    It may very well be that the style your drawn to are not sold weighing 18lbs or less. I know as I've looked for rims that I kept on finding that the rims I really liked were either to heavy or I could not get them in 45mm offset.
    Pretty much any rota rim is decently priced and light weight. Several Konig rims are very light, the Kosei K1 rims from tirerack are light and have 42mm offset. 5zigen fighter rims from discount tire are nice and also 42mm offset.
    Jun 2002
    so is the only bad thing about heavy rims is they slow you down and have bad gas mileage? cause i can deal with that cause i am goin for all looks/sound not really performance at all
    Central California
    Hey that's cool I understand. Just make sure the rims have the correct specs 4x100mm and never less than 40mm offset.
    I don't know about the bad gas mileage, but heavy rims will slow you down and they do compound the NEED for a good suspension as far as the ride goes.(Meaning if your struts are worn or weak, you'll notice it even more with heavy wheels).
    Jun 2002
    I plan on getting some koni specials all around, and I am tempted by the nopionline price on suspension tec 2" springs, are those some good springs? I am gonna try and find the prelude front arms but if i cant then I am gonna get the camber kit. do I need a camber kit in the back with those springs?
    Man if it wasnt for you I would be so lost I appreciate all the help man
    Central California
    Those springs are nice, I like their spring rates. Several members have them. I ran some of their springs awhile back on a different car and I liked those springs. I really don't think you'll need rear camber correction on a 2" drop. In any event our members that are dropped 2" to 2.25" are split down the middle on wheather or not rear camber correction is needed. I'm not about to take sides on that
