Results 1 to 7 of 7
Thread: dcoe guys- question about manifold vac
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    well my manifold is almost ready to put on the car, I just need to drill/tap holes for the vac adv, PCV, and brake booster. So I need some advice on the best way to do this. here is what I came up with. In that pic you can see that I tapped into each runner and joined all of them together, then I have the brake booster coming off one end and the PVC/vac adv. coming off of the other end. So will this work? Is there a better way that I could do this? thanks for your help!
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    That looks good to me... How big was the tap?
    I'm thinking if it's too big it one runner might interfere with the other runners?
    Nov 2002
    88 Accord
    Nebraska
    I havent tapped anything yet, do you have a suggestion on what size it should be?
    A20A1's Avatar
    Sep 2001
    around a 1/2" ID. Or make it a little larger then the brake booster hose from the manifold to the "T" and then the arms of the "T" use the same diameter hose as the brake booster.
    The vacuum line for the dizzy is 5/32"
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    My question is if the vacuum from the runner on the manifold is stronger than the vacumm the distributor got from the stock setup is that not going to throw off the advance in the distributor?
    Jul 2002
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    Dude, that setup in your graphic looks just like mine
    All the
    I used 3/8 hose for everything. I've got some kind of reducer thingee that runs it to the vacuum advance on the ditributor
    I'm sure you could go into all kinds of hellish detail to find out exactly what vacuum draw each item (brake booster, pcv, advance) should have in proportion to the total vacuum if you wanted. I just said, "Screw it, let's just start the car!"
    :lol
    Mike Clark
    Nov 2002
    88 Accord
    Nebraska
    All the
    :lol
    is yours all joined together like mine?
  1. Replies: 5
    Last Post: 09-08-2009, 10:41 AM
  2. DCOE manifold help
    By myaccord7 in forum Performance
    Last Post: 04-22-2004, 11:05 AM
  3. NEED DCOE manifold
    By TWOLOUDNPROUD in forum Trading Post
    Last Post: 12-15-2003, 05:38 PM
  4. dcoe manifold
    By 89AccordHatch in forum 3geez Accords
    Last Post: 10-04-2003, 12:49 PM
  5. dcoe manifold question
    Last Post: 11-25-2002, 11:00 AM
