Results 1 to 19 of 19
Thread: vac lines from black box
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    ok does any of the lines from the black box control the secondarie or the choke? if not can i just rip it out and plug all the holes that the lines were attached too?
    97 Dodge Neon
    Athens AL
    if only i knew what lines were the choke and what lines were the secondarie. i i want to remove everything but them two. can some one tell me?
    shepherd79's Avatar
    Falling Waters, WV USA
    https://www.3geez.com/showthread.php?...0&pagenumber=3
    this is waht you need to do to keep vacuum secondary.
    about the choke, i have no idea. i don't need it.
    97 Dodge Neon
    Athens AL
    so i just hook a vaccum line going from the round thing the the port Sec ?
    shepherd79's Avatar
    yeap. it is the way it works
    97 Dodge Neon
    Athens AL
    when u did the how to, what did u do with the lines that are for the timing advance? the plastic lines coming from the distruibuter??
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    you can keep the plastic lines... it should be better cause they can withstand higer vacuum then the rubber lines can.
    shepherd79's Avatar
    i just removed all the rubber lines and replaced them this silicon ones, wrong color (red) but who cares. they are better than rubber and they can withstand higher temperatures.
    97 Dodge Neon
    Athens AL
    so were do i plug them after i remove the hard lines? were at on the carb? cuz the how to doesnt say
    LX User mindlos's Avatar
    97 Prelude Base
    Minneapolis, MN
    The vacuum advance on the distributor along with the power valve port on the carb go to the manifold vacuum port shown on the step 5 picture. Look at the picture on step 4. There is a port labelled "intake manifold." That is the power valve port. Hope that helps...
    97 Dodge Neon
    Athens AL
    so i use the 2 way vaccum connecter to connect em both?
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    WHY DOESNT EVERY ONE JUST GET A WEBER??????????????????????????????
    Travis
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I will have to second that opinion!!!!! Your car won't be good unless it has the best parts. So you need Weber!!!!!!
    Disclaimer: Not responsible for people that blow off hands while using dynomite.
    97 Prelude Base
    Minneapolis, MN
    Yup!
    shepherd79's Avatar
    Travis
    well, i am sorry. some people just don't have that kind of money to through around.
    97 Dodge Neon
    Athens AL
    LX User cody509's Avatar
    i clicked the link that shepard posted and it was just a link to the vacuum removal how to section?
    basically for an extremely visual and sometimes slow learner as myself....
    what do i need to keep (vacuum line wise, as in which numbers etc) to still have my a/c, choke and no manual secondary, is the basic question that i always come up with
    so?
    86 LX
    myspace
    A20A1's Avatar
    Sep 2001
    Everything is labled here:
    https://www.3geez.com/showthread.php?t=11067
    All the numbers are circled and are in big bold black print in the vacuum removal diagram. Directly below the diagram is an image for the vacuum secondary for those that don't convert to strictly manual secondary.
    All you have to do is find the corresponding vacuum numbers in your engine, follow the black lines to see where they connect to on the carburetor and the engine, all the vacuum ports are colored YELLOW. Any vacuum port (YELLOW) that needs to be plugged has a RED STAR on it. You can replace the old vacuum hose with new 5/32" Vacuum lines. BLUE "T" fittings are the 3-WAY VACUUM LINE connectors.
    so with everything like that, the black box can go?
    86 LX
    myspace
  1. vac. lines
    By ShyBoyCA6 in forum 3geez Accords
    Last Post: 11-07-2009, 02:32 PM
  2. ATTN: Black 3G's!!! Post you black 3G here!
    By Night Rida in forum Classic Honda Pics & Videos
    Last Post: 09-03-2007, 09:21 PM
  3. Replies: 10
    Last Post: 10-10-2004, 11:00 AM
  4. VACUUM LINES ?'s
    By mattalica in forum 3geez Accords
    Last Post: 02-09-2004, 06:49 PM
  5. A way to get black trim black without painting them!
    By neoblue89lxi in forum Interior & Exterior Care
    Last Post: 09-23-2003, 10:33 PM
