I've finally started work on my 3 gee, the cold ass weather has been stopping me. My friend moved back home and now we can use his nice garage to get to work. I tried replacing the pressure power steering hose, but it was too far back for me to get to without a lift, so i sent it to a garage to get it installed. The next project is to get rid of the undercarriage rust once i get it back. Now there is a little bit along the door panels, some decent size holes. We'll grind off the rust and put undercoating stuff on it. The question I have is there is one nasty spot on the right wheel well. There's a hole thats only about 2 inches in diameter on the underside, but it has rusted into about a 5-5 inch hole right underneath the fuse box. It's gone, i mean i can poke my finger right through it. What can i used to seal this up, cause theres like 3-4 inches between the holes though the wheel well and top of where it's under the fuse box. Another question is, what do you guys recommend for holes that are about 4 inches lengthwise, and 2 inches wide near the door panels. Fiberglass patches or what?
Thanks
Chris
