Results 1 to 14 of 14
Thread: Bigger fuel line
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    Bigger fuel line
    would there be any performance increase on a carbed accord if u increased the fuel line size?
    LX User mindlos's Avatar
    97 Prelude Base
    Minneapolis, MN
    Fuel line size wont do nothing unless your float bowl is running out. Even then that would point to the pump not being up to snuff rather than the fuel line unless it is very very restrictive. That doesnt mean more performance it just means dehandicapping.
    I know what you are thinking though. To that I would say you would have to rejet the carb and get a bigger pump if necessary to satisfy the bigger appetite. Since right now the carb is optimized for fuel economy, emmissions, and smooth idle. As you have noticed people just get webers and get different jet kits to suit their application. Mike comes to mind. Beats rejeting the stock carb I bet. What a hassle it would be. Especially since they didnt think "reconfigurable" when they made it.
    Nov 2002
    Ridin Dirty in New York
    yeah unless youre running more than like 300hp at the wheels with a turbo you shouldnt need new fuel lines. If your flow sucks, check your filters and pump first.
    shepherd79's Avatar
    Falling Waters, WV USA
    if you gonna make your fuel line bigger, you may as well replace the pump with high flow pump.
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    a better pump and larger fuel line is not needed on anything less than dual DCOE 45's
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    Carb would be ok with the bigger fuel line and pump...but you might encounter some mix problems......Id say go with the webbers.....
    -Travis-
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    How much would it be for re jetting the weber? I think I was told before I should get a different accelerator jet. I guess I should try to figure out how to get more pull out of the throttle cable b/c my weber does open fully and I'm frusterated b/c I flattend that bracket out and drilled a new hole and it still doesn't open to WOT.
    PhydeauX's Avatar
    Eastern Penna
    You didn't drill the hole close enough to the throttle shaft. Weber jets are between $4 and $6 a piece. I think the dgv pump jet is an expensive one though.
    andy
    Mankato, Minnesota
    So the hole I drilled is too far to the right and not close enought to that pivot? I guess I will try it again this weekend. I am tired of not racing people b/c I don't have it working right. I guess I will have to get that weber book. I have no idea where the jets are.
    97 Prelude Base
    Minneapolis, MN
    Think about it this way, if you are moving along the circumference of a circle for a specific distance, the smaller the cicle is the greater the change in angle from the start point (bigger pie). If you can measure the total throttle cable travel when you push the pedal to the floor (get some help and make sure there was no slack) you can use a formula to help you not have to try over and over again.
    Lets say to get WOT (from --- to |) the angular deflection is T, your cable travel is X, and your unknown: the distance from the absolute center of the pivot-barcket attachment to a hole on the bracket, is R.
    C = pi * 2R,
    360/T = C/X, ... C = 360*X/T
    pi * 2R = 360*X/T
    R = (360*X)/(2*T*pi)
    T must be about 90, pi = 3.14, then you measure X. After that you will be in Trump City. Should get you close enough not to have to try again.
    Feb 2003
    1987 2.0 Si prelude
    no there wont be there will just be less pressure in the fuel line, less efficiency
    Feb 2003
    1987 2.0 Si prelude
    if you want to increase performance dont touch your fuel line its the carb which controls fuel so if you wanna increase power adjust your throttle, making the mixture rich also comes with its minuses, you will sacrifice power for fuel economy.
    Feb 2003
    1987 2.0 Si prelude
    98 Av6 3oh
    Sacramento, CA
    OOoooooo very right -Lude
    -Travis-
  1. EFI swap fuel line
    By Bassmastry101 in forum EFI Tech
    Last Post: 11-21-2012, 07:30 PM
  2. hepl cannot got fuel line off fuel filter
    By 88vert in forum 3geez Accords
    Last Post: 02-04-2004, 09:20 AM
  3. In-line fuel pump?
    By 89accordlxi in forum 3geez Accords
    Last Post: 09-03-2003, 04:24 PM
  4. Fuel line?
    By CoAsTeR in forum 3geez Accords
    Last Post: 11-19-2002, 10:53 AM
  5. Help..Carotman - fuel line
    By GreenMachine in forum EFI Tech
    Last Post: 06-21-2002, 08:03 PM
