Results 1 to 2 of 2
Thread: Is this thermo valve A?
    Aug 2015
    1986 Honda Accord LX
    CA
    I have a 86 Honda Accord lx, 4spd auto with carb. Is what I have circled in red thermo valve A it has vac lines# 17,18 and 19 attached? If it is, does it have anything to do with the fast idle?
    When I warm the car up it doesn't kick down on its own anymore I have to bring it down with the gas pedal. When the car is driven awhile and is warmed up and it sits for about 5-10 mins I get back in and the car wants to go into fast idle again. Could this be the problem?
    Is there a way to check it?
    How hard is it to change it?
    Do I have to drain some antifreeze out?
    Will I need to bleed the system when done?
    [IMG][/IMG]
    Re: Is this thermo valve A?
    I can't help you cause I don't have a carbed Accord. But I can give you the Honda manual oracle:
    https://www.dropbox.com/sh/vtyhl48z5...udl0xk_Oa?dl=0
    Spend some time reading through section 11 of the 1989 Accord Service Manual and you'll understand everything a lot better.
  1. Is this thermo valve A?
    By lx 1986 in forum 3geez Accords
    Last Post: 02-05-2017, 04:50 PM
  2. busted thermo valve and other vacume snaps need ideas
    By labeledsk8r in forum 3geez Accords
    Last Post: 10-18-2006, 01:01 PM
  3. Thermo gaurd
    By 86lxihatchback in forum Classic Honda Community Chat
    Last Post: 04-23-2006, 07:52 PM
  4. Thermo Valve(B-60) replacement
    By Lester Lugnut in forum 3geez Accords
    Last Post: 01-26-2006, 06:51 PM
  5. Thermo valves?
    By soljaboy2000 in forum 3geez Accords
    Last Post: 01-17-2004, 04:57 PM
