1986 Accord LXi, 330k miles
I'm pretty sure that my oil leak is coming from the lower breather tube.
Question? Is there a substitute tube can I use? What would be the diameter? Or is the $40 online part my only option?
(Backstory)
Last summer I changed the oil pan gasket, upon reassembly decided to reused the lower breather tube.
The leak appears to be dripping down to the exhaust pipe causing a bit of oil smoke. The leak is only noticeable just after a drive…. it drips into a puddle, then stops for the rest of the night. My guess is when there's crank case pressure the oil gets forced out around the connections (BTW, I plan on going through the entire PCV system just to rule out any blockage).
Also, I can rule out Dizzy (replaced), no evident oil around area. Replaced valve cover gasket (dry just below cover). Replaced the oil filter housing gasket and oil pressure sending unit seal.
