Results 1 to 7 of 7
Thread: gear hunting?
    87 LXi Hatch (5-speed)
    Riverside, CA
    Question gear hunting?
    heres a good one...
    Almost every time that I go around a corner and sort of step on the gas comming out of the corner, my auto trans doesn't seem to find the right gear at first. It sort of "tries" 3rd (the gear it was in before the corner) and then revs a little and slips into 2nd. Would this happen to all cars about this old or is it just me? Can i do anything to stop this from happening other than not touching the gas until im out of the corner? I know that some of the tranny fluid is not honda atf but i didnt think it would do this...
    thanks in advance for your help!!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    i have heard that getting honda ATF is critical. try that and see if it fixes your problem. i dont know autos, but thats what ambers old car did when it was low on fluid, so maybe you should flush it with honda ATF!
    i have good atf and mine does it occasionally... im not really sure what causes it. You might benefit from a change...
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    fluid level _is_ low
    I've had the exact same thing happen on turns,go tot he dealer....get 6 quarts of honda ATF, drain the fluid and dump three quarts in there...repeat in 6 months.
    Jan 2003
    1989 Accord SE-i
    Marlton, NJ
    Here's what mine did: slowing down to about 25 (usually to take a corner) and then speeding back up again, it would drop down to 2nd and rev like a mother, then upshift. If I slowed down to 20, it would downshift while still slowing down, and wouldn't rev like a mother. It was low on fluid and the mechanic says it had the wrong kind of fluid. He put in "fluid X" which is allegedly equivalent to Honda ATF, and now it is much smoother, usually still does it. However, if you manually downshift to "D3" while still slowing, it won't do it. Will probably use Honda ATF next time.
    Riverside, CA
    So I think the general consensus is use Honda ATF.... It seems to solve almost all transmission problems....
    thanks for everyone's help... I just have to find a dealership now
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    My car does that to, but it's just how you take the corner. just before the corner I brake which is slowing down the engine and then the tranny slips into a lower gear. But if you give the engine a second to catch up to the tranny it'll be fine. then you can give it more gas and it's fly.
    R.I.P. Died on 7/2/03......
  1. new junkyard hunting thread
    By lostforawhile in forum Classic Honda Community Chat
    Last Post: 11-21-2011, 11:22 AM
  2. 1981 Hatch Hunting Vac and Oil Leaks throw in a little paint...
    By Dslattz in forum 1geez Tech & Performance
    Last Post: 11-23-2010, 03:35 AM
  3. Gear Hunting '88 LX-i
    By 88cool in forum 3geez Accords
    Last Post: 03-26-2010, 05:28 PM
  4. Engine Hunting Revving & Issues 1987 2.0Si AUSTRALIA
    By Rob Hocking in forum EFI Tech
    Last Post: 02-08-2010, 05:20 PM
  5. Hmmm Radiator Hunting Time
    Last Post: 12-13-2008, 11:24 PM
