Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: Idle shaking and vibration ugh!!
    Feb 2003
    1988 Accord LX
    Unhappy Idle shaking and vibration ugh!!
    sup this is my first post so bare wit me. So i got this reall annoying idle vibration when for example im at a redlight, the car goes nutz!! at first i was like this is niiiice for my back and *hit and well..... but now its just annoying, sometimes when i press the air con. button the idling shaking gets less but can someone tell me the source or the reason, that would be friggin awesome.
    thanx yall
    10/Honda/Ridgeline
    NJ
    idle shaking as in it drops down below the 900 idle rpm? IF so u need to adjust the idle screw and screw in the idle stop screw.
    THe idle screw i am tlakign about is a plastic knob at the back of the carb near the firewall. turn it clockwise or counter clockwise till the desired rpm is reached
    THe idle stop screw is on the left side of the carb i believe (standing infront of the car that is) and screw it in to make the butterfly valve open a lil bit.
    If it staggers its due to poor AF mixture. U can also adjust that by adjusting the AJC (Air Jet Controller)<< the one with three thick vaccum lines go A-B-C
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Before you decide to mess with carb settings, change the spark plugs(properly gapped), change air, fuel primary, and fuel secondary filters, and make sure your wires and distributor are in good condition.
    3axap.
    SEi User 88 Accord DX's Avatar
    Jul 2002
    '95 del Sol VTEC
    San Angelo, Texas
    plug gaps help this problem significantly
    -T.C.
    Originally posted by HostileJava
    are you making fun of me because I think coroncho80 is hot?
    Nov 2002
    2003 Nissan Sentra SE-R Spec V
    Daytona Beach, FL
    He is feeling engine vibrations through the steering wheel and dash, his motor mounts are worn.
    Chris Jones
    Hotshot CAI, Hotshot Header, Thermal R&D Exhaust, AC Autotechnic Reverse Indiglo Gauges, SW Autoworks Pulley, ES MM
    14.9 @ 93mph
    Jan 2003
    1989 Accord SE-i
    Marlton, NJ
    I had (and still have) this problem, and my mechanic says it's the hydraulic motor mount at the front (or rear -- I forget) of the engine. I think it's like $150 or so. The other mounts could be worn too, they are less expensive. I just had one replaced and the part cost like $85 or so. Don't know about the labor.
    10/Honda/Ridgeline
    NJ
    there is no hydraulick motor mount. Its just a rubber mount. You would be better off with urathene mounts when u get em replaced.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    OEM Honda motor mount for the front one is liquid filled. Aftermarket motor mount for the front one is rubber. The rest of the motor mounts are rubber.
    Your shaking idle problem sounds like worn motor mounts.
    SEi User 89accord_lxi_coupe's Avatar
    Jan 2003
    Louisville, TN
    mine has done the same thing ever since i got it. dont have the green to get it worked on. it doesnt get really bad unless ive been up at 60 for a while, then get to an area with lights. when i stop it goes crazy.
    Nolan
    check my profile
    I'm on AIM at Maxaccord3G
    I AM THE STIG
    Feb 2003
    1989 Honda Accord Si
    Brisbane, Queensland, Australia.
    I just joined. I've had this vibration problem while idling for over a year in my 89 Si. Mechanic said fuel injectors needed cleaning. So I take it to a specialised mech. But then fuel injector guy said injectors were fine, my engine mounts were worn. So $AUS400 later new engine mounts but 1 week later vibration creeps back, so I take it back to fuel inj guy who increases idle speed...lasts a few days...now vibrating again. Though its vibrating less cause idle is a bit higher and the engine is firmly mounted it is still very evident and worse with a/c on. WHAT THE HELL IS IT! Valves? I think I will have the injectors cleaned anyway...I think that makes reasaonble sense coz I cant think of any other cause.
    Nov 2002
    Daytona Beach, FL
    Im sure it has nothing to do with a rough running motor. The original poster didnt say his car was running bad, just that vibration is transferring through the car.
    These cars are old. Alot of stuff is worn. Im sure thats why it shakes, its just the way it is. My 89 accord did it too, and ive seen alot of other Hondas do it. I just chose to live with it, it wasnt that big of a deal.
    Chris Jones
    14.9 @ 93mph
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    Before you change the idle rpms, you should make sure the ignition timing is correct, pcv valve is OK, and your oxygen sensor(s) are working correctly.
    A while back, I had someone fix the "idle" with an adjustment, only to have to back it off when these other things were corrected (by me).
    Nothin' extra
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    That's probably not a good idea. The fluid in the front mount helps to dampen out vibration. There was a guy on the board a few months ago that replaced his front mount with a non OEM solid rubber mount and he still had bad vibration problems until he installed the Honda part. Urethane wight work well for the other mounts, but i wouldn't use it for the front.
    Mike
    86 accord ex-i
    roughly how much are the front motor mounts i need to change it on m se-i
    Jan 2003
    1989 Accord SE-i
    Marlton, NJ
    Feb 2003
    1988 Accord LX
    yeah thanx for the reply guys this really helps me out cuz obviously theres a whole buncha shit that could be wrong with it, i can probably learn to live it, but it just sux when youve wasted someone on a light and you get to the next light thinking your car is the BOMB!! and then brrrrr it shakes like its afraid of something i dunno..... thanx though!:lol
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    I have it in my '89 and I had it in my '87 too... I think it's just something inherent to our cars. If you look at how they were designed and built, you'll notice that the car's overall design is fairly simple and straightforward, without a lot of extra fluff. I think a side-effect of this is the fact that vibrations get into the cabin real easily.
    My friend's mom's 97 or 98 Monte Carlo doesn't shake at all when idling and still, but you look at how that car was designed and it's complicated as hell... I'd trade "vibrating" for "the ability to work on my car without computers" any day of the week.
    88 accord lx-i
    N.Y.
    hehe, well that crazy vibrating thing has been with my accord since the day my dad drove it off of honda's lots way back in 87. you get used to it after a while, i jus drop it into neutral if it gets too bad...
    88 Accord Lx-i
    Pioneer DEH-7400MP
    Infinity Kappa speakers all around
    new headlamps...hehe
    Aug 2003
    82 Accord LX (looking for good home), 92 Legend LS, 87 Accord DX, 97 Integra LS
    Austin, TX
    Re: Idle shaking and vibration ugh!!
    I replaced all my mounts a while back with aftermarket and still have the bad vibration in the steering column/wheel. If I loosen the tilt part of the column, the vibration goes away. I bumped the idle up slightly and that helped, but I'm ready to try the Honda fluid filled mount and see what happens. Before doing that, while it's idling and vibrating I'm going to put the floor jack on the oil pan. I suspect the vibration will go away. If so, I will change the mount.
    Which one is the fluid filled mount? Is it the one that is just behind the radiator in front of #3 or 4 cylinder that is just big and round? Not sure how soon I'll get it done, but I'll post an update when it happens. Thanks!
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    man where did u get aftermarket mounts mmm.....
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    I have this exact problem and took it to the Honda dealer. They said both front and rear motor mounts were worn. They ordered the parts and I have an appointment this coming monday to have them installed. I'll post whether it fixes the problem or not.
    Aug 2003
    Austin, TX
    I got the aftermarket mounts from AutoBone. I'd wait to find out what nfs480 results are before buying mounts.
    nfs480 - I guess your steering column rattles like hell and if you loosen the tilt, the rattle goes away? If so, please ask the Honda dealer which mounts have fluid in them. If it's only the big round one in the front, I'll get one of those from Honda assuming your results are good. Thanks!
    nfs480's Avatar
    Rogers, MN, USA
    Quote Originally Posted by Poodlehead View Post
    Yeah, that's exactly what happens. I'll make a note to ask them and will be sure to post Monday night when I find out.
    Sep 2006
    89 accord lxi efi
    mississippi
    which mounts did u get the side and back from auto bone
    LX User GraniteLXI's Avatar
    Sturgeon Bay, WI
    My 3gee doesn't have this problem, even when my engine was running VERY rough on half the engine a while back when my ecu died I had almost no vibrations, and none at all now that its back and running well again. My stepsister's 88 LX did have this problem tho, at stoplights her car felt like it was going to vibrate apart, was somewhat irritating, but I think her mounts were shot, and her car also had a ton of rust. The vibrations didn't really hurt anything tho, she put a ton of miles on it b4 totaling it into the back of a Vette that wasn't paying attention lol....got 1200 for it from insurance when she only paid 600
  1. Vibration @ idle - 89 Exi
    By MoDawG in forum 3geez Accords
    Last Post: 09-17-2019, 09:41 AM
  2. Idle Vibration, Reduced Power, etc.
    By 89fuelie in forum EFI Tech
    Last Post: 12-24-2011, 07:04 PM
  3. shaking / vibration at 70-80mph
    By AC439 in forum 3geez Accords
    Last Post: 02-05-2008, 02:35 PM
  4. Low Idle and ALOT OF VIBRATION!
    By bradccool in forum Carburetor Tech
    Last Post: 01-13-2003, 08:19 AM
  5. Steering wheel shaking at idle/TUNE UP??
    By n88accordLX-i in forum 3geez Accords
    Last Post: 05-25-2002, 06:54 AM
