Results 1 to 10 of 10
Thread: Motor mount
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    Motor mount
    the motor mount that sits on the drivers side of the egine bay.
    are the ones for the LXIs different? like stiffer or stonger since the LXIs had more power than the LX's ?
    Nov 2000
    I believe they are all the same. The lower mounts are the ones that go bad, anwyay. I have heard of the mounting tab that is part of the block breaking on the mount you are talking about, but it usually some sort of blow to the underside of the engine to do that.
    97 Dodge Neon
    Athens AL
    can we get stiffer ones or is there a way to make the stock ones stiffer?
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Why do you want stiffer ones? A stiffer motor mount will transmit more engine vibration to the rest of the car.
    Mike
    LXi User BoredRec's Avatar
    Nov 2001
    1988 Honda Accord LXi
    Las Vegas
    Yeah, but you also don't lose as much power transferring torque from the flywheel to the wheels.
    1988 Accord LXi Sedan
    Custom Cold Air Intake -- Custom Exhaust -- Neuspeed Springs -- ACT Stage II Clutch
    Alpine 9815 -- MTX 2300X -- 2 JL 10W3V2's
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Once the engine has shifted position due to the applied torque how does the softer mount continue to absorb the engine's energy? Does that small amount of energy lost during changes in torque (like during shifting) really amount to anything significant?
    Mike
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    I do remember reading on other Honda sites about solid mounts or inserts or something, for those seriously modded/boosted guys. I guess it helped control wheel hop during takeoff or something along those lines.
    I guess in a racing application though, that small amount the engine moves during a shift, and the time it takes to get back to the spot where it's applying power to the wheels after the shift = lost time accelerating and an overall slightly slower ET time. Same principal as a short shifter = faster shifts = more time accelerating and less time decelerating (during shifts).
    -Jared
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Stiffer (or solid) mounts make sense for racing when the extra 0.01 second matters and vibration and comfort don't matter a bit. I just think it's probably not the best choice for a car that will probably drive almost exclusively on the street.
    Mike
    Jun 2002
    1988 HONDA ACCORD LX
    from ALASKA stationed in Korea
    where do i get replacement engine mounts? and are they hard to install?
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Try the Honda store, but expect a nice price for em.
    Best bet would be the boneyard. You can actually test the mounts for play at the scrap yard to see if they are still good.
    -Mike
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
  1. new motor mount
    By lostforawhile in forum Project Central
    Last Post: 02-14-2011, 08:43 PM
  2. useing a rear mount to replace your front motor mount
    By Civic Accord Honda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-24-2008, 06:14 PM
  3. Motor mount fix
    By sunderland in forum Restoration & Custom Fabrication
    Last Post: 11-22-2005, 09:56 AM
  4. Bad Dog Bone(motor Mount)
    By HondaBoy in forum Performance
    Last Post: 05-11-2003, 09:24 PM
  5. front motor mount
    By franks89sir in forum 3geez Accords
    Last Post: 08-19-2002, 10:10 PM
