Results 1 to 7 of 7
Thread: damper fork & driveaxle
    1986 accord lx-i HB 5 spd, 1988 prelude Si 5spd
    Raleigh, NC
    Lightbulb damper fork & driveaxle
    is it possible to remove the passenger side driveaxle without removing the damper fork? by the looks of it it looks like you can just maneuver through it.. but has anyone done this? if possible i would like to avoid removing the fork(the pinch bolt's head is broken off, the bottom bolt is frozen.. ugghh) thanks!
    SEi User 2old_honda's Avatar
    88 Accord
    Nebraska
    if you disconnect the hub from the lower ball joint and then remove the 3 bolts that hold the strut/shock assembly to the strut tower, you should be able to pull the strut/shock assembly down and swing the hub out far enough to remove the axle.
    Raleigh, NC
    thanks i'll try that this weekend
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    The CV joints will not fit through the fork.
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    YES THERE IS A WAY!! just CAREFULLY take the CV shaft apart and it'll fit right through. Take the shaft apart where it goes into the transmission. I saw my mechanic do it and it works, just be careful not to break the sliding bracket that hold the boot on.
    R.I.P. Died on 7/2/03......
    yeah you can do that, but its usually easier to get the bolt off than to take apart the inboard cv...
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    I've done this way. It works. That's how I removed the axles when I replaced my clutch. Be very careful to keep the inner CV assembly clean - completely free of dust/dirt/debris. If it gets "contaminated", then you'll be replacing it soon.
    Mike Clark
  1. Damper fork pinch bolt
    By Acid X in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-29-2005, 01:41 PM
  2. damper fork bolt frozen
    By jayshonda in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-19-2005, 09:21 PM
  3. broke damper fork bolt!
    By brianc85 in forum 3geez Accords
    Last Post: 11-18-2002, 09:16 PM
  4. Damper fork bolt
    By CARBurn in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-05-2002, 07:53 AM
  5. MISSION IMPOSSIBLE........damper fork removal!
    By bigpoppa88 in forum 3geez Accords
    Last Post: 08-16-2002, 02:42 PM
