i want to put a 89lxi motor into my 86lxi..... would there be anything extra that ill need?
extra O2 sensor, or use existing 86 exhaust manifold.
1988 Accord LXi Sedan
Custom Cold Air Intake -- Custom Exhaust -- Neuspeed Springs -- ACT Stage II Clutch
Alpine 9815 -- MTX 2300X -- 2 JL 10W3V2's
I thought that the vacuum line setup was a little different between the two also.
Mike
itd be tough to put the 89 intake into the 86 all the vacuum lines are different as well as the vacuum control box. You could do it but it sounds like alotta work. You could also just keep the 86 intake and exaust manifold on the 89 engine but you wouldnt gain any power that way
are the two engines different? I thought that 86-89 was the same cept for some sensors.
- Col Jack O'Neal - Stargate sg-1."If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
