Results 1 to 9 of 9
Thread: Fuel pump only runs for 1 second,
    Mar 2004
    89 accord dx auto carb
    az
    Hi All,
    '89 Accord DX ( carb) automatic, original owner, 70,000 mi.
    I don't drive the car everyday, if I did it would start up just fine. So when I start it I have to turn the switch to on 20 to 30 times, I can clearly
    hear the fuel pump start but it only lasts for a second, if that.
    What I've done recently, changed the fuel relay ( under the dash), changed the ignition starter switch and today changed both fuel filters and the pump.
    The new pump sounds like the old pump, comes on for a second............. it took about 50 to 60 turns to get gas to the carb and it
    does not help to crank the engine.
    Any ideas would be greatly appreciated.
    FYI, the strainer at the bottom of the pump was gone ... after 28yrs, who knows ,
    Jan 2016
    1987 Honda Accord LX-i
    California
    Re: Fuel pump only runs for 1 second,
    You've done everything I would think to do & stuff I wouldn't think of. I guess bad wiring between starter switch & pump telling pump to turn on?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Jan 2016
    California
    In my '87 (injected) there is a fuel pump fuse under the hood. If yours is similar, couldn't hurt to swap it out for a new one, & clean up the slot. Poke around in there for debris, corrosion etc.
    You're only going to hear it one second during cranking thats normal. Is there no gas getting to the carb? Check the filters one on the left rear up by the rear control arm beside the tank, another under the hood somewhere around the line as it comes up the firewall driver side very low corner closest to upper fender.
    Mar 2004
    az
    Thanks for the replies, It eventually does start it's just that it takes all of that to get the fuel up to the carb. Is there a difference between "start" and "run "
    once the engine is running then I am assuming the pump runs all the time ? I read somewhere if you're in an accident, the engine dies but the
    ignition is still on, something shuts off the pump after a minute or so.
    I would be looking at fuel bleeding off on the carburetor side somehow. Do you have a leaky float? Or possibly you are driving it so infrequently that the fuel in the bowls is evaporating completely?
    Mar 2004
    az
    Evaporating ??? It rarely gets over 125F here. Looks like a carb rebuild is in the future or a Webber. Thanx
    LOL. I guess we found the problem.
    New carb wont fix a fuel pump that wont pump or wont pump enough volume.
    You can measure a pumps flow into a PLASTIC bucket times for one minute.
    You can find out if the safe relay is really working or not. On the EFI cars its looking for spark from the coil to prove the car is running,negative side of the coil I believe.
  1. Fuel Assembly , Pump , & Fuel System Location
    By A20A1 in forum Carburetor Tech
    Last Post: 05-10-2016, 01:27 AM
  2. Replies: 10
    Last Post: 09-30-2015, 07:05 PM
  3. Fuel meter sending unit - not fuel pump hanger
    By deathblood6 in forum Wanted
    Last Post: 08-29-2014, 05:18 PM
  4. Fuel Filter? Fuel pump?
    By Bass Man in forum 3geez Accords
    Last Post: 05-19-2008, 03:38 AM
  5. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
