Results 1 to 7 of 7
Thread: Loud whistling sound
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Hey guys,
    Every morning when I start my car and let it warm up it tends to whistle really loud.
    Sometimes after it has warmed up and idle becomes stable at 900 rpm, I open the hood give her gas a l hear that freekin whistle again? could that be? I'm totally baffled!
    It's not the PCV vlave either. I think I posted this one before but I don't think I got a solution to this strange prob.
    So any help would be greatly apprieciated.
    Thanks all.
    -Mike
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    i think this is the answer
    http://lisupras.com/wooo.html
    anway i cant offer any advice but hte sound board is fun to play with!
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Generally whistling sounds from the engine are caused by loose belts. When the belts are cold, they slip sligthly at start-up but once they warm up more they grip better. This could also explain why you hear the noise when you throttle up the engine once it is warm.
    Hope this helps.
    3axap.
    Banned
    Nov 2002
    87 Honda Accord Lxi
    Tempe, AZ
    my intake whistles when i step on the gas, its tight!
    Aug 2001
    1988 Accord LX-i (RIP)
    could it be a vacuum leak?
    This useless space for sale, please inquire at the front desk.
    LXi User BensAccordLxi's Avatar
    1995 Eagle Talon TSi Turbo
    Tucson, Arizona
    It could be a vacume leak. If you have an aftermarket intake, it could be that. My intake sounds like a blow off valve on a turbo.
    R.I.P. 1988 Honda Accord LX-i hatchback
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I say a vacuum leak from the rear intake manifold vacuum ports.
    It's a metal tube with 2 ports sticking out of it... one is slightly larger then the other.
    Anyways the tube is just pressed into the port at the rear of the intake manifold... once and a while it shakes loose and you need to press it back in... my suggestion is if it's really loose... you might want to epoxy the sucker in there for good.
  1. 89 Honda Accord loud popping sound
    By levon2008 in forum 3geez Accords
    Last Post: 02-13-2008, 02:23 PM
  2. loud clicking sound at abut 1000-5000 rpm
    By steve-024 in forum 3geez Accords
    Last Post: 05-26-2005, 12:10 PM
  3. Very Loud Sound is it a Rod Bearing?
    By X-Lr8 in forum 3geez Accords
    Last Post: 12-23-2004, 06:41 PM
  4. Weird whistling sound when in 5th gear.
    By Chrome_thangs in forum 3geez Accords
    Last Post: 02-23-2003, 03:43 PM
  5. Loud pop sound??
    Last Post: 06-21-2002, 04:46 PM
