My Car is not running and i might have blown the fusible link that runs from the starter to the altenator, can anyone tell me where the fusible link is located at on a carb 2.0l engine?
NGK Spark Plugs/Wire Set | EX-I interior swap | Dynamax Super Turbo Muffler
Gotta love rebuilding 3Geez's!!
I think all the main fuses are in the engine bay fuse box... they have a plactic cap over them, you have to use a philips head screw driver to remove them.
The fuse box is by the battery... if you didn't know. and the fusible links are closest to the front of the car within the fuse box.
thanks!,
I already blew the altenator fuse, i replaced that but its still not running after a boost, i wanted to check the fusible link before replacing the altenator.
