Results 1 to 19 of 19
Thread: putting 17s on my car
    88 Prelude Si with 4WS
    Cherokee County
    I am about to put 17 inch Focal f5s on my car. do i need to do any mods on my car so that they fit on there?
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    it depends on if youre car is lowered, and if the rims are the correct offset...
    i think you want like a 40mm offset. also i dont think your tires can be any wider than 205, but i could be wrong..
    why dont you take 15 minutes and PUT THEM ON YOUR CAR, and see if they go on or not...... then post pics of course!
    2.0Si User Grant2k's Avatar
    Jul 2002
    well, they'll go on for sure (if the bolt pattern is right). you won't have any problems as long as your offset is right, and no, your tires can't be wider than 205. i guess you may have to roll your rear fender, but that may or may not have to be done. you'll know when you start driving.
    Cherokee County
    I am putting them on the rear cause I got them from a friend and the 2 front ones are warped and the tire tread sicks balls....I am just worried about the control arm and if it is going to hit it... I think that they are 205/40/17 Focal f5s and they are the right bolt pattern and I have pics of them but I am not sure how to post them up...I have a pic of the sitting beside my wheels that are on my car....I edited the pic so you can not see the wheels behind it
    *Content exceeds signature guidelines*
    88 Prelude Si with 4 Wheel Steering and a JDM B20A
    Jul 2002
    you really have to worry more about the tire width in the front i beleive.
    LXi User Chrome_thangs's Avatar
    1989 Honda Accord LXi Coupe
    That dirty south!! Columbus Ga.
    your only putting two on the back?
    Cherokee County
    http://www.geocities.com/afrealm/accord.html my car is kinda dirty and the inside look alot better than you think it is...I have started inside and then I am going to start on the outside soon, that is why I just got the wheels
    Jul 2002
    it looks good like this but it's gonna be a lot higher once you put them on.
    oops, it's a geocities site. can a moderator please delete this post.
    Cherokee County
    what is that supposed to mean?
    Jul 2002
    well the car is sitting on 14s, so when you put the 17s on it is possiblly going to raise it close to an inch. as for the other thing for some reason you can't like geocities cites with the [IMG] codes.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    not true... its gonna be the exact same height... just looks taller... the over all diameter is the same, so the car wont get taller... it just looks taller
    Travis
    Cherokee County
    what is IMG codes? does anyone know of another easy site i can put my pics on that is free....I will put my friends 01 civic on there..I ahve only seen one this color before...
    LXi User pearldrop's Avatar
    Feb 2001
    93 Prelude Si..shaved and bagged - 96 S10 bagged and bodydropped, 99 Suburban dropped 5/7 on 22s
    NW Wash.
    You can link pictures from geocities, you just have to rename the pics to end with ".txt" instead of ".jpg"
    Then they work just fine.
    Cherokee County
    LXi User InfinityAudioLXi's Avatar
    '86 Ford Bronco II XLT, 1989 Honda Accord LXi Sedan
    Baghdad for now
    what is the max offset?
    I can get a set of four quantum tek s13 and four ziex for $400. the offset says it is a +45 on the 17x7.5. will that work? the tires on them are 240/40/17.
    Save a Tree, Wipe ur A$$ with an Owl!
    Don't Drink & Drive, You Might Hit A Bump and Spill it!
    bobafett's Avatar
    Longview, WA
    there is no way in hell that will work
    Nov 2002
    '89 Accord LX-i
    Poughkeepsie, NY
    240 is massive... thats like corvette tires..
    Mods:
    90/91 CRX Si Wheels on Yokohama's, HP Racing 4'' oval exhaust, Arospeed Coilovers (0-4" drop, slammed at about 3.5" now), Modified Integra Short Ram Intake, Clear Front Bumper Lights(wired on w/ hyperwhite bulbs), Sidemarkers, White Interior Trim(Console, Vents, Handles, etc...), Removed Emblems, Type-R shift knob, Aiwa CD Deck, Sony Xplod 6x9's
    17.06 @ 80.9 mph
    http://www.cardomain.com/id/slammedlxi
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: what is the max offset?
    Hey, haven't seen you in awhile Ummm, I hope the 240 width is a typo Widest you could get away with would be 215. The offest is perfect, you should not have to roll the rear fenders with the 215 width.
    Now I d
    Baghdad for now
    lol, oops
    lol, oops! I guess i took a little to much medication lastnight, or alcohol. yeah that was a typo. they are just the normal 17 size tires. but thanks guys. and hi back to you too Jim, long time no chat. been a little crazy with school, work, my daughter, and maybe another one on the way.
  1. putting on a different coil...
    By A18A in forum 3geez Accords
    Last Post: 01-11-2007, 02:50 PM
  2. Putting 15's on an 89 lx-i...
    By offthahook in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-10-2003, 01:08 AM
  3. Putting 6x9's in a 88lx?
    By 88accordlxcarb in forum Interior & Exterior Care
    Last Post: 04-14-2003, 08:27 AM
  4. putting tv
    By hondarcr34 in forum Interior & Exterior Care
    Last Post: 12-11-2002, 06:51 PM
  5. smoking after putting oil in my car
    By Jerren in forum 3geez Accords
    Last Post: 05-06-2002, 09:01 PM
