Results 1 to 3 of 3
Thread: Stock HU wiring problem
    LX User jay's Avatar
    2000 Honda Civic Si
    Upland, California, U.S.A.
    I still have my stock HU (which doesn't match any Accord HU I've ever seen pics of... ), and my [stock] speakers have been working on and off for a while now. I'm not much of an audiophile, so it didn't bother me much; I'd just turn it up to compensate for the missing speakers.
    Well, lately all of the speakers have been going out at once. I've found that if I reach up and right from under the driver's side dash I can poke at a wire bundle to get all the speakers to come on and go off. Unfortunately, I can't get it to stick in any good position.
    Anyways, audio is a low priority for me, but I'd still like to hear something while I drive. I just want to know what to expect when I pull my dash apart in search of the problem. Is it common for the stock wiring harnesses to go bad, or is the some loose connection I'll be able to jury-rig back together?
    Let me know; thanks!
    1989 Honda Accord LX-i Sedan R.I.P.
    replaced by:
    2000 Honda Civic Si Coupe
    shepherd79's Avatar
    Falling Waters, WV USA
    i don't think you have to take the dash apart.
    just take the HU out and see if it is a connection. sometimes they go bad. you never know. if it is connector you can try to fix it. or you can get yourself a cheap HU and cut that sucker out, ( i did on mine) and splice the wires. it is that simple.
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    The reasons your speakers don't work is probably that they are blown and your HU is gone. You can probably pick up some
    cheap-o speakers if it's not an issue with you. but You DO NOT HAVE TO cut your wires in the back, just buy a wiring harness for your year accord. then wire the harness to the nes hu you buy and plug both ends in. Then you're all set, simple as that. getting the hu out you have to come up from behind the radio, you have to go under the dash there should be 2 screws way up there, then just pull it out from the front, mount the other one in there and you're all set!!!
    R.I.P. Died on 7/2/03......
  1. stock radio wiring colors
    Last Post: 06-14-2008, 09:53 AM
  2. Coil/wiring problem...major pain
    By led_fut in forum 3geez Accords
    Last Post: 11-24-2006, 10:06 AM
  3. A wiring problem for the A Team
    By redrum in forum EFI Tech
    Last Post: 08-29-2006, 08:38 AM
  4. WTB: stock radio wiring harness
    By 89cordlx in forum Trading Post
    Last Post: 11-04-2003, 02:21 PM
  5. Wiring problem, wasn't sure where to put this...
    By toastyghost in forum Performance
    Last Post: 07-11-2002, 12:21 AM
