Results 1 to 5 of 5
Thread: tightening front sway bar end bushings .....
    LXi User AC439's Avatar
    86 LXi
    FL
    Question tightening front sway bar end bushings .....
    I have poked around forum for a while and can't seem to find a good answer.
    Just changed out the original (yep, 31 years old) front sway bar end bushings today. I bought the set from Amazon (poly, red color). The installation was pretty straight forward but not sure if I tightened it correctly.
    After I fit everything together, I hand tightened the nut to the set (threaded in about 3 - 4 turns). At this point, no thread at the end of the bolt showing beyond the nut. I then started tightening the set and the bushing were being compressed. I used standard wrentches but they were all too easy to tighten. After more tightening (and more compressing of the bushings), I got about 3/4" of the bolt showing beyond the nut. I was a bit scared if I keep going, I will break the new bushings so I stopped. I read somewhere to use 22ft-lbs but even at this point, I think I was not even using this much torque.
    Also, the nut is not a locking type. I am considering getting another nut to double it as a locking nut.
    Test drive definitely showing a little tighter on the turns and I needed less effort to turn the steering wheel.
    Did I do it right ?
    -AC
    Re: tightening front sway bar end bushings .....
    Yes i would use lock nuts.
    The link to the sway bar will bind the bushings some. I would just try and keep it even on both sides so not to pre load the bar either side. It one of the few things I would not go strictly by the torque call out.
    86 LXi
    FL
    thanks for reply. Drove car today for about 20 miles or so and definitely feel the steering is better and turns are tighter. Got to get nuts from home depot as locking. Prob get some stainless steel nuts. May take some pics when I can get to it in a few days.
    I think I put some blue Loctite on mine and have had no trouble in the several dozen thousand miles since.
    86 LXi
    FL
    I ended up add a nut to lock it in place. Before I added the second nut, the original nut was still in same place and did not loosen. I think this will do it.
  1. How To Upgrade Your Front Sway Bar Linkage Bushings To Polyurethane
    By firefighterwhite89 in forum Restoration & Custom Fabrication
    Last Post: 07-29-2013, 10:47 PM
  2. Replacing the stock Front sway bar End Link bushings.
    By firefighterwhite89 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-04-2012, 06:11 PM
  3. urthane for the front sway bar bushings
    By lostforawhile in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-15-2006, 08:50 PM
  4. Front Sway Bar Bushings
    By stolenracer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-06-2004, 10:29 AM
  5. Sway bar bushings
    By 88WhiteLX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-14-2003, 03:16 AM
