Results 1 to 21 of 21
Thread: Lx-i electrical problems?
    Nfld, Canada
    car: 88 accord lx-i (canadian version)... Automatic with fuel injection
    ok... symptoms:
    1) the engine lights is always on, the ECM's (aka ECU) led light is just on, all the time. I thought it was supposed to blink so you can read the codes!
    2) when engine is running, it won't go past 3750rpm... it bounces off that rpm like it's hitting a rev limiter
    3) a lot of the time, a minute or two after starting the car I get a clicking noise from beneath the dash and the engine usually cuts out. Sometimes one of the valves in this thing:
    clicks at the same time. If I unplug the box the clicking valve stops, but the under-dash click does not. Car eventually dies if not immediately and will not restart for at least few minutes. Very rarely the car runs fine for hours. Very rarely.
    She's sitting in the backyard now until I can figure out the problem... someone help her... doesn;t she look sad?
    WTB: 4th and 5th gen OEM headlights and corners in good shape. Even single lights.
    1995 Honda Accord EX-R | 1988 Honda Accord EX-i | 1987 Honda Accord LX (R.I.P.)
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    not having an injected accord , I shouldn't answer, but I've read about it enough times to know its the ( drumroll please).....
    main relay. $50 or so US..some say they can be repaired (simple resolder job)
    fuel injection guru's are free to heckle me if I'm wrong
    Nfld, Canada
    main relay? ok.. this is a start. It's a common problem here? I've done some searching but turned up nothing. Can I get a used one from another car?
    Jan 2001
    1989 corolla all-trac wagon
    cincinnati, oh
    yeah, you can pull them from junkyard cars. do a search on here for main relay. i can't remember if it was here or on AF, but someone had some pictures, etc.
    3geez member since January 28, 2001
    Nfld, Canada
    I did a search of all forums for any date and nothing came up
    Nfld, Canada
    musta been on the old board
    Oct 2001
    87 Accord EX , 5spd , Manual
    it was on AF board !
    but i save everthing so here it is !
    MIKE
    Nfld, Canada
    Dude! Thanks a lot. Much appreciated!
    Is that the fuel injection main relay, the one located beneath the coin tray? If not, can you tell me where it is located?
    Can you also post a link to the posts about this problem on the AF? My searches are not turning up anything there. Thanks.
    Oct 2001
    yes that is the one !
    about it's location i am not sure ! but i guess you 're right ( i have a carbed car )
    about the AF thing , i think our posts were deleted from there !
    they really got pissed off by us ! :lol
    i hope this helps !
    MIKE
    Nfld, Canada
    Excellent... this helps soooo much. My manual shows where it is so it should be a snap to remove. Thanks.
    I don't think anyone mentioned, that to find out the ECU code(s), look under the driver's seat. There will be a box, with a flap covering the led. With key "on" count the blinks, may be more than one code tho. Then check FAQ section for codes. Do that first, before replacing the main relay. Which, btw,isn''t hard to replace like u said! I'm gonna try to attach a pic ..maybe. But with the Main relay, it won't start.
    Steve
    Whoops, here' the main relay if it shows up, the red base with white plug going into it. The cover should lift off the hinges.
    Steve
    Nfld, Canada
    Steve
    that's the thing... the LED is on all the time... the little light in the box under the driver's seat right? It doesn;t blink... it's just on.
    Oh shit, ok. I think someone had the light on thing & it turned out to be his ecu was fucked! But, did you try resetting the ecu? If that doesn't help, don't know what else to suggest, check connections? Might need a cheap replacement(boneyard). Hope that's not it, good luck!
    Oct 2001
    BTW to reset ECU you don't have to remove battery terminal , just the ECU fuse !
    MIKE
    Nfld, Canada
    I pulled the ecu fuse and the check engine light remained on and nothing else changed. I think I'll take a little trip to the scrapyard and try to find a relay and ecu.
    Thanks all.
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    I hate to say this, but it sounds to me like your ECU has brain damage. I would say that the processor chip took a major hit. Your best bet would be to get a replacement ECU from a wrecker. However, if they are like the ones here, they remove them from the cars before they go out into the yard. They will charge you a premium price for it, but it is still less than what the dealer would charge.
    Nfld, Canada
    Ok...I'm on the lookout for a new ecu... 88 accord, auto w/ EFI. Does the replacement HAVE to be be from an 88 with auto/efi or can they be from other years? I assume it has to be from another car with auto/efi right?
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    The ECU you get must be from the same engine type as what is in your car. I might be mistaken, but the 86/87 FI engine is slightly different from the 88/89 engine, so I am assuming that an 89 ECU would be interchangable with yours.
    Oct 2001
    if i were you i'll try to find on from the same car ! ?
    i know it's not easy
    MIKE
    Nfld, Canada
    well, I'll certainly take an ecu from an identical car if possible, but lately the number of 3rd gens being scrapped around here is limited.
  1. electrical problems
    By gtmst3 in forum 3geez Accords
    Last Post: 01-26-2010, 01:39 PM
  2. electrical problems
    By crazykamper in forum 3geez Accords
    Last Post: 10-22-2005, 04:48 PM
  3. Electrical Problems
    By 87RedAccord in forum 3geez Accords
    Last Post: 12-16-2004, 07:14 AM
  4. electrical problems
    By 88'er in forum 3geez Accords
    Last Post: 11-04-2004, 04:55 AM
  5. Electrical problems
    By cdixon311 in forum 3geez Accords
    Last Post: 02-10-2004, 04:08 AM
