Results 1 to 15 of 15
Thread: Going turbo with carbs possible ?
    LX User AWH's Avatar
    Feb 2017
    Honda Prelude BA2 1987 2.0i-16V. B20A1
    the Netherlands
    I'm thinking of a turbo on my 2 gen. Prelude but it is dual carbed. Can anyone tell me what i would need to be able to tune it as best as possible with carbs ? I read about fuelpressureregulator at least,but what more ? I assume i will have to be able to adjust timing as well ? If so,How ?
    Will i have to go obd0 ?
    And what stands "obd" for anyway ?
    I'm reading myself in a bit,but all the info makes my head spin,so sorry for all my stupid questions.
    Auke.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: Going turbo with carbs possible ?
    Obd on board diagnostics. You would have to go OBD1 to properly tune it and you would have to be fuel injected for that.
    Feb 2017
    the Netherlands
    You're always helpful,thanks.
    Noticed trying to turbo a carb is "never" going to be properly tunable,so will leave that idea.But understand that obd0 and turbo can be done,don't need FI for that ,do i ?
    There should be a solution to turbo obd0,i read. Some sort of adjustable fuelpressure regulator.
    What is the difference between no obd and obd0 , or is that the same .
    Auke.
    Quote Originally Posted by AWH View Post
    Auke.
    Research "blow thru carb", is what your looking for. Be tricky with duel carbs but single is what most people do.
    My friends running a nice setup with a cheap turbo and a Fitech on a 302 Ford.Pretty easy and cheap.
    Feb 2016
    Florida
    Auke.
    The adjustable fuel thing you're talking about I think is a fmu fuel management unit. It tricks the fuel system and I believe you have to be fuel injected for that to work too. Talk to( knifemind) he's doing some similar blow through turbo project
ID:	8461   Click image for larger version.
ID:	8462   Click image for larger version.
    Feb 2017
    the Netherlands
    "Research "blow thru carb", is what your looking for".
    I've been reading through there,so much info...hard to get a grip on it and keep things apart.
    Would supercharging be an easier route with carbs,or does it have the same challenges ?
    Feb 2016
    Florida
    Any forced induction mod is going to have challenges I would start out by building the motor
    carotman's Avatar
    Montreal South Shore
    Converting to EFI will be less of a challenge and will deliver better results in the end.
    Feb 2017
    the Netherlands
    Nice links,thanks !
    Not sure yet to do blow/draw-through,or convert to FI first and go from there. First have to gather everything anyway so will take a while but will use that time to get some more knowlegde about this particular stuff.
    Really envy some of you guys because of your perseverence and knowhow.Appreciate the help given.
    Question :you guys talk about the lxi distributor and ecu to convert,but i assume that the 2 gen Prelude FI distributor and ecu, which came straight after the carb,same engine, will also do ? The same even i think as the lxi ones ? Or not ?
    And i thought that "dizzy" meant distributor but is doesn't ? What stands dizzy for ?
    Auke.
    Feb 2016
    Florida
    Nice links,thanks !
    Auke.
    Dizzy is the slang word for distributor. Post some pictures of your distributor and head so we can see if a distributor adapter plate will fit. Have you thought about just putting a nos kit on it
    Feb 2017
    the Netherlands
    NOS is not going to do it for me .I want some real crafted stuff for the "long" run. Something good or nothing at all...
    In the "classic Prelude" i have a question about a dizzy,it is the same model as i have at the moment on my carbed A18A1,exept i have only one vacuum-exit on the black box,this one has two, and i don't believe i have the square little whitish thing on the bottom of it ". Mounting-legs are the same though.
    Auke.
    Feb 2016
    Florida
    Auke.
    From the looks of it it looks like a carbureted distributor and that square Little Box is the igniter unit. I don't know about the carbureted distributor maybe someone else will chime in about the vacuum lines
    Feb 2017
    the Netherlands
    Ok,thanks for answering.
    My ignition control module is black and is mounted on the firewall,so i didn't recognize this one.
    Now you know about the two mounting-legs,how about that adaptorplate ?
    Auke.
    Feb 2016
    Florida
    I'm actually using a carbureted piece that holds the distributor cuz the original one broke. One of the mounting holes is off with the adapter plate.3 out of 5 holes line up
ID:	8475   Click image for larger version.
ID:	8476   Click image for larger version.
  1. Replies: 121
    Last Post: 07-18-2007, 11:37 AM
  2. for the turbo guys/wana go turbo/dream of going turbo
    By ZackieDarko in forum Performance
    Last Post: 01-14-2007, 11:22 PM
  3. um help with carbs
    By Noodle in forum Carburetor Tech
    Last Post: 01-08-2006, 02:54 PM
  4. FPR for carbs?
    By Mantis88LX in forum Carburetor Tech
    Last Post: 09-24-2002, 11:36 PM
  5. 2 carbs!
    By smallballn in forum Performance
    Last Post: 08-13-2002, 02:35 PM
