Results 1 to 6 of 6
Thread: Petroltankswap in carb to FI conversion?
    LX User AWH's Avatar
    Feb 2017
    Honda Prelude BA2 1987 2.0i-16V. B20A1
    the Netherlands
    If i would go from carb to FI,would i have to swap petroltanks too ?
    As now the carb has a 3 psi fuelpump not mounted inside the tank ,that will have to be a high pressure pump with FI,but do i also need the tank of an FI with an internal fuelpump ? Or can i just change fuelpumps and keep my old petroltank ?
    Auke.
    Re: Petroltankswap in carb to FI conversion?
    EFI 2g Prelude has external fuel pump too but they have baffles around the pickup tube to maintain constant fuel supply for the fuel pump when youre running low on fuel.
    You can get away with just the carb tank if you maintain more than 1/4 tank of fuel although the best way to do it is to swap the tank or run a surge tank like I do.
    What about the return line?
    Feb 2017
    the Netherlands
    Good point. That's just why I'm asking around here. Why does a carb only need a fuel line and an airbreather/vacuum-line,and does a FI also need a return fuelline ? So that would be three lines in total ?
    Auke.
    I added a 7mm hard line for the return and plumbed it back to the fuel filler neck pipe although I don't recommend this because it somehow would build too much pressure and it would start to leak there no matter what I did. The best way is to add another fitting on top of the tank itself (on the cover thinggy for the sending unit, idk what its called now omg) along with the stock feed line to the fuel pump.
    carotman's Avatar
    Montreal South Shore
    The return line is attached to the pump so this isn't a problem.
    The only "problem" with the carb tank is the missing baffles.
    I need these parts!
  1. CARB TO EFI / EFI TO CARB Distributor Conversion
    By A20A1 in forum Carburetor Tech
    Last Post: 08-29-2006, 06:08 PM
  2. 2G carb to EFI conversion?
    By Coy in forum 2geez Accords
    Last Post: 03-28-2006, 11:03 PM
  3. Question for Carb to EFI conversion
    By Caddy in forum EFI Tech
    Last Post: 12-11-2002, 09:55 PM
  4. carb to efi conversion
    By Mantis88LX in forum Classic Honda Community Chat
    Last Post: 08-15-2002, 06:14 AM
  5. Carb conversion?
    By CoAsTeR in forum General Engine Swaps
    Last Post: 06-01-2002, 10:37 AM
