Has anyone try this distributor from Ebay? Not expensive, about $100 a piece.
My dist is original and after going through years of frustration of not able to get the right vacuum advance for FI cars (using a carb vacuum now as a work around). I have definitely pulled it out few times re-greased it but the sleeve/bushings for the two weights in the mechanical advance are worn out. The two weights are kind of loose and I think my base timing is off due to them worn out. Since the connections of the carb vacuum advance are pointing downwards towards the thermostat housing, I don't have much room for timing adjustment.
So I think I might just go get this flea bay unit.... the vacuum advanced on it is a metal housing and I am not sure if it will give the same advance curve compare to OEM........
