Results 1 to 3 of 3
Thread: crossover
    89 accord lxi sedan
    milwaukee, wi
    crossover
    if anyone has ever hooked up a componet set on an 89 lxi HOW THE HELL did you run wires through the door?? i looked at what i would have to do and it seems like so far i dont even want to bother. i couldnt even find where the wires from the door going into the car go because the damn fusebox is in the way. if anyone can help, then please do
    89 Lxi
    So Cal
    THe way i did it was to drill a hole in the door and the door jam then take ruber gromets and put them in the holes runthe wire using a smal section of fule line to hide the wires and protet themwhen the door shuts. this way was easy to do and looks clean.
    LX User 89accordlxi's Avatar
    see user name
    IA
    how big is the crossover. If small, just use the factory speaker wire that is in the door and hook it to your crossover. Then run the wires for the tweeter and mid from there. You will need to use some creativity to mount the crossover inside the door. That is how I did it. This will only work if you have a small or medium size crossover, unless you can some how find a way to mount a bigger on inside the door.
    Later, peace.
    89 Lx-i
    Performance: K&N filter,custom CAI, Accel coil, MSD 6aL ignition, magnecor wires, high flow injectors, FPR, sport exhaust,Tokico springs/struts
    Appearance: white gauges, side markers, headlight conversion, clear bumper signal/fog light conversion, SE-i center armrest and cupholder, SE-i leather seats
    17" ADRs with 205/40/17 khumos
    future plans: 16" or 17" rims(can scratch that one off the list 9-12-02), headers-high flow cat.-cat back piping. Rear disc brakes from SE-i, reground cam.
  1. Old Crossover
    Last Post: 06-18-2006, 08:13 PM
  2. PPI X-3 Crossover
    By ronin in forum Trading Post
    Last Post: 04-05-2004, 08:54 AM
  3. Passive Crossover... without an amp?
    By RustyHo88 in forum Interior & Exterior Care
    Last Post: 08-14-2003, 11:12 PM
  4. tweeter/crossover mounting
    By ShawnS in forum Interior & Exterior Care
    Last Post: 04-12-2003, 07:15 AM
