ok, can some one explain to me how in the world do you mount mikuni carb. they have round back and no holes to be screwed through.
so how do you mount them?
i am currently biding on set of 4 mikuni carbs
ok i think i figured out. this link says that they use rubber mounting flanges http://www.pro-flo.com/proflo_intake_manifolds.htm
why do they use rubber? and will it withstand engine heat?
this website has exploded views of Mikuni and Keihin carbs http://www.pro-flo.com/proflo_carburetors.htm
ok i just found this http://www.pro-flo.com/proflo_ysr50_carbs.htm
it is only 22mm but as you can see it has adapter plate that will allow for manifold vacuum.
I also found NOS system for mikuki carbs http://www.edelbrock.com/motorcycle/...s_systems.html
that would be nice to have.
ok, does anyone have pictures of mikuni carb setup on A20 engine?
i know i have seen them around this board. there was prelude with mikunis and there was old civic with a20 with mikunies.
can some one post pictures or give me a link.
thanks.
