Results 1 to 11 of 11
Thread: JDM Manual Transmission Swap
    1989 Accord Hatchback DX
    Vancouver
    Has anyone here done a JDM manual transmission swap?
    If so, did you come across any issues?
    I saw online that someone posted a JDM manual transmission for an 89 accord and purchased it.
    Do i know for sure that it is indeed an 89 accord transmission? I can't say for sure, I just took his word for it.
    There also weren't any markings on it to help me google a serial number.
    However, it does look very similar except I noticed a few differences when I took off the USDM transmission on my car.
    1. The USDM shift rod has a bolt that I can remove, whereas the JDM did not and I had to grind it down and punch it out. (Problem solved)
    2. The USDM transmission has a speed sensor attached to it with a hole for the speedometer and 2 hoses. I was told these 2 hoses were for the power steering. Is this true?
    The problem is that the JDM transmission only has a slot for the speedometer cable. That slot doesn't even have a slit cut into it for the clip of the speedometer so that it would stay in place. I'm not sure what to do about that. Also, it doesn't have the 2 holes for the hoses that is on the USDM speed sensor.
    I'm pretty new to this so do I have to connect those 2 hoses? If not, what will happen? How would I keep the speedometer cable in place?
    I also tried to remove this from the jdm transmission by undoing the bolt holding it in. There's also a spot where I could pry on it but it was on so tight that I chipped off part of the metal.
    Perhaps someone has an idea how I can get it off?
    Any help is appreciated. Thanks!
    PS. I've already removed the broken transmission from the car.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: JDM Manual Transmission Swap
    Are you able to use parts from your old transmission? Can you post up some pictures so we can get some ideas of what's going on
    Vancouver
    I realized I would need to swap out the transmission housing as the JDM one is quite different. Only 3 or so of the tranny bolts line up. The housing is shaped slightly different so all the other bolt don't line up at all even though both dowels are in place.
    Swapping the tranny housings is unfortunately out of my scope and ability. Has anyone done a tranny housing swap that could offer some advice?
    Feb 2016
    Florida
    Quote Originally Posted by DemonicAngel View Post
    Are you sure you got the right honda transmission ?
    carotman's Avatar
    Montreal South Shore
    Maybe it was for a Civic.
    I need these parts!
    Maybe it's a JDM B20 trans!
    carotman's Avatar
    It would be nice but I bet it's from a Civic since there's no provision for the power steering variable assist on the speed sensor. This has to come from a car that has no power steering.
    I need these parts!
    LX User JJ'sAccord's Avatar
    Dec 2016
    1989 honda accord LXI
    South Carolina
    i might have a spare tranny if you cannot figure out a way around it... shipping will be expensive too... but youtube has tons of things about transmissions just gotta weed out the bad ones lol
    Feb 2016
    Florida
    I'm interested in what kind of transmission is that close of a fit
    Vancouver
    I ended up buying another transmission and have the car up and running. Thanks for the input but I still haven't figured out what tranny it is and which car it came off of. However, as one person said, maybe it's for a civic since it doesn't have a provision for the power steering variable assist on the speed sensor. I really don't know.
    Feb 2016
    Florida
    post some pictures of it
  1. 1988 HONDA ACCORD Transmission - Manual Transmission, (2.0L, 4 cyl), FI eng
    By JoshydillingerLX in forum Classic Honda Community Chat
    Last Post: 11-01-2014, 02:46 PM
  2. add oil to manual transmission
    By hondalx85 in forum 2geez Tech & Performance
    Last Post: 08-20-2010, 04:30 PM
  3. Which Manual Transmission Mount needed For Swap?
    By Swap_File in forum 3geez Accords
    Last Post: 03-06-2006, 09:44 AM
  4. manual transmission
    By beck432 in forum 3geez Accords
    Last Post: 11-15-2004, 08:28 AM
  5. Transmission swap
    By possum in forum Classic Honda Community Chat
    Last Post: 11-06-2003, 02:18 PM
