wheelhorse2347
Hello All
I have a 1988 Honda Accord LXI with 154k miles. Daily Driver I bought this car last year, this time.
I've been having an issue that's been driving me insane, and making me late to work. In the mornings it's been getting down to about 45 degrees the past few days. I leave at 530 am, and when I go to start the car, it just turns over with not so much as a sputter or a hint of starting. This car has a new distributor, and a new ignition coil, new wires, new plugs. It appears there is NO spark when this happens, but I need to get my tester on it to make sure, and you can hear the fuel pump turn on and smell the gas. I've already resoldered the fuel pump relay under the dash and I checked it to make sure everything was kosher.
I've been having to ride the motorcycle in (COLD LONG RIDE) to make it to work. When I get home around 330, and go to start it, it starts right up and runs great like nothing was wrong with it.
I can read electrical drawings, and use a multimeter, so I'll be trying to find some today to try to troubleshoot, but as you know, it's hard to troubleshoot a problem after it's fixed itself. I suspect it has something to do with some important bit loosing connection due to contraction or something like that. Can the ICM be bad? I kept the original one from my old distributor.
Any advice would be appreciated.
