It's a bit smaller then I wanted... I couldn't get 3" pipe at the time so I used 2.50"
1.50" Secondary bore @ Throttle plate
1.25" Primary bore @ Throttle plate
so a 2.75" - 3.00" is the best bet.
As for the larger opening... when you go from a small area to a large area the air will slow down... but a if you have a slightly larger area then the intake opening it will help draw in air.
the intake is hardly a good idea for top end... a velocity stack would be better... but space is limited to those not willing to cut holes in the hood.
